low boost turbo with stock everything else
Ive thought about putting a turbo on my xa and not changing anything else except for adding a nitrous wet system without using the nitrous and adding a wideband to get it jetted properly. Im thinking that I can get the nitrous system to spray fuel when boost kicks in using a window switch. I only want about 2 psi at the most and am thinking the stock fuel system and ECM programming can handle that. Im not concerned about the cost as I have a couple of turbos laying around, one of which should do the trick. Got lots of extra piping and a couple of BOVs and can pick up a used FMIC cheap around here. Ill get a cheap manual boost controller to keep boost in check. Think of it like setting up a nitrous system but using turbo boost instead of nitrous for the oxygen enrichment.
So hit me with your thoughts, concerns, criticisms, or just plain flames.
Thanks!
Thanks!
my06tc
06-25-2015 12:18 AM
clickclickw00t
02-18-2015 08:57 PM
darkshadowofxdeath
12-03-2014 06:59 PM
ScionLife Editor
11-25-2014 03:00 PM
