Air Conditioning Issue
Old 07-23-2016, 05:43 PM
STSCowboy's Avatar
Default Air Conditioning Issue
My serpentine belt cut a hole in one of my AC hoses. I replaced the hose, pulled 26 in of vacuum and serviced my AC System. The AC blows cold at idle but the more rpm the engine spins the warmer the ac gets. After about 2000 rpm, the air out of the vents is just ambient temps.
The local temps are 100° to 105°, what kind of pressures should I be seeing on the low and high side at idle and at say 4000 rpm?
STSCowboy is offline
Old 07-25-2016, 09:16 PM
HATEnFATE's Avatar
does this also happen when your A/C is on recirc?
HATEnFATE is offline
Old 07-25-2016, 10:04 PM
STSCowboy's Avatar
Yes
Old 07-27-2016, 01:43 PM
HATEnFATE's Avatar
Toyota says these are the possible issues.......
1. Volume of refrigerant
2. Drive belt tension
3. Refrigerant pressure
4. Cooler compressor assy
5. Pressure switch No. 1
6. Condenser fan
7. A/C amplifier assy
8. Heater control & accessory assy
9. Wire harness or connector
Throw me your email address and I'll send you something that might help.......
Rhymenoceros
Scion xD Drivetrain & Power
07-02-2016 10:12 PM
tenshun
08-04-2015 05:22 PM
AJC
Scion tC 2G Aero & Exterior
04-17-2015 08:02 PM
its_ikon
110
08-03-2013 04:03 AM
snart
02-03-2004 08:56 PM
Quick Reply: Air Conditioning Issue
