Installed T1819 HU into my 2004 and having radio reception problems...
I did a standard install using the 2 connectors that my xb has to the back of the new HU. I used an antenna adapter which came with the T1819.
My question is: the radio reception is not very good, at least not nearly as good as the stock 2004 HU.
I have read the discussion about the antenna amp and similar problems with aftermarket installs.
With this new Scion HU do I need to splice the antenna adapter's blue/white wire to the Black/Red wire from the R2 connector (pin -(R2 is the blue 10 pin connector in the 2004) In 2004 and after, the Black/Red pin powered the antenna amplifier. The splice might be necessary if pin 8 out from the T1819 does not have the former function.
Does anyone know if I need to do this splice?
Thanks in advance.
Phil
Thanks in advance.
Phil
Solution to poor radio reception with upgrade to T1819
To answer my own question:
Yes, if you upgrade your Scion's head unit to the newest T1819 stock unit, you do need to install a jumper wire from the blue/white wire on the antenna adapter installed on the HU to the black/red wire on the 10pin connector that fits into the back of the radio.
I can understand that the jumper is necessary for an aftermarket non-Scion head unit. I am surprised that this connection was not already wired into the T1819 unit, as it was in my original HU.
A small but important thing to know!
I hope this helps someone upgrading.
clickclickw00t
02-18-2015 08:57 PM
TheRedBox
31
12-02-2003 04:53 PM
