Besk one's blue Cold Cathode Trunk Mod
Old 11-18-2003, 05:56 AM
Besk_one's Avatar
Default Besk one's blue Cold Cathode Trunk Mod
http://homepage.mac.com/besk_one/PhotoAlbum12.html
some picture of the install, took me almost 4 hours to trace the right wires and get everything working, these are just a few of the many steps and a few of the finised product - i'm adding 2 more 6" tubes and will post some new pictures of how the trunk looks when i get those in!
Brian
Besk_one is offline
Old 11-18-2003, 03:38 PM
Wagonistas
randode's Avatar
damn, damn, damn! you beat me to it! that is exactly what i was going to do. it looks great though. are the lights on a switch? or on all the time?
randode is offline
Old 11-18-2003, 04:11 PM
Besk_one's Avatar
the lights are wired to the dome light circut coming from the switch on the trunklid so whenever someone opens the trunk (or a door) the lights go on along with the dome light!
Besk_one is offline
Old 11-18-2003, 04:21 PM
projxB's Avatar
that looks really cool. nice work
projxB is offline
Old 11-18-2003, 04:55 PM
scionracerxb's Avatar
looks tight....where did you buy the parts from, and can you give a list of parts?...thanx
scionracerxb is offline
Old 11-18-2003, 05:03 PM
Besk_one's Avatar
it's basicly two 6" Cold Cathode Flourecent Lights with inverters (you need 2 inverters)
but this week i'm adding 2 more tubes to make it brighter (2 on each side, i have dual output inverters)
you also need some wire, some shrink tubing, electrical tape, some velcro tape, hot glue (or zip ties), a working understanding of electrical theory and a whole lot of time to make it stealth and clean.
You can get the lights at http://svc.com
everything else at a hardware store.
Besk_one is offline
Old 11-18-2003, 06:27 PM
scionara's Avatar
Cool lighting mod. Thanks for sharing the wiring info.
scionara is offline
Old 11-18-2003, 06:32 PM
Besk_one's Avatar
get a volt meter tho before you start back there, i forget which wire is the 12v and which is the ground circut for the dome light switch - you'll know the ground because it will read 12v when the switch is off, and ground when the dome light is on (sounds weird, but trust me the wires are behind the switch so it seems backwards but it's not)
Besk_one is offline
Old 11-18-2003, 06:40 PM
scionara's Avatar
it looks like you got the ground hooked up to the red wire and the hot wire on the blue wire.
scionara is offline
Old 11-18-2003, 06:58 PM
Besk_one's Avatar
ya i know, but it's allways best to double check, just in case, don't want anyone frying their stuff because of me
Besk_one is offline
Old 11-19-2003, 04:21 AM
quadraphonic's Avatar
Well done.. very nice install.
quadraphonic is offline
Old 11-19-2003, 04:55 PM
sensez's Avatar
nice job! :D
when i do get some cathodes...
can you help me install?
sensez is offline
Old 11-19-2003, 05:01 PM
Besk_one's Avatar
you can get the tubes at http://svc.com
Besk_one is offline
Old 11-19-2003, 05:13 PM
Wagonistas
randode's Avatar
<shameless plug> i have kits in stock </shameless plug>
randode is offline
Old 11-19-2003, 05:17 PM
Besk_one's Avatar
or pm randy and get a pre wired kit for under your seats
randy are you going to be producing a trunk kit too? if so i'd be gald to help you design it
it's a little more complex than the underseat install but in a kit form it should only require stripping some insulation from 2 wires, shrink tubing them and wrapping the harnass back up and running the wires across the trunk!
Besk_one is offline
Old 11-19-2003, 05:35 PM
Wagonistas
randode's Avatar
i may develop a trunk kit if there is enough interest.
randode is offline
randode
44
06-29-2004 04:19 PM
randode
11-20-2003 05:46 PM
Besk_one
11-17-2003 09:28 PM
Opr8r
18
10-30-2003 05:28 PM
BlueBox
9
09-25-2003 04:36 PM
Quick Reply: Besk one's blue Cold Cathode Trunk Mod
