Scion xB Wiring Colors
Old 07-21-2004, 12:12 AM
Founder
scionlife's Avatar
Default Scion xB Wiring Colors
CREDITS: This article was written by a dedicated Scion Life member. Please let out Inazuma know if this article was helpful to you!
DISCLAIMER: Scionlife.com does not take any responsibility in what you do to your car. This FAQ could be filled with incorrect information. You could be voiding your warranty if not installed by a certified mechanic or dealership. It is quite possible that you can totally mess up your car by using this as a guide to install anything. This can result in serious bodily injury, death, dismemberment, sexually transmitted diseases and so forth to you and anybody else in case of an accident resulting from failure to take safety precautions and/or following the instructions in this write-up.
Preface:
I know a lot of you will want this precious info Its from a good source. I will be installing an alarm in the next few weeks and will be taking questions from anyone who needs help. Anyways, enjoy!
-- Inazuma
Scion XB Wiring Colors
NOTES:
*1 Meter these wires while turning the key in the driver door key cylinder. Unlock requires a double pulse. Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/red (-) in the passenger kick in a 14 pin plug.
*2 Also found at the top of the fuse box in a 13 pin plug.
*3 The data link connector is below the fuse box. The tach wire is in pin 9.
*Administrator's Note: this Post is over 15 years old and the Original Diagram has long expired and no longer available.
______
scionlife is offline
Old 10-04-2004, 03:50 PM
opie2727's Avatar
Default Alarm
Are the wiring colors the same in the tC? I am trying to install a power window roll/up module for my alarm and can't figure out what color the power window wires are.
opie2727 is offline
Old 10-13-2004, 07:06 PM
ayS
ayS's Avatar
should we present this to a installer in case they are not aware or are these pretty universal or easy to figure out by a installer?
ayS is offline
Old 11-05-2004, 02:44 PM
BrianxB's Avatar
dont worry about presenting this to an installer. They should have this program where this info was stolen from.
BrianxB is offline
Old 11-14-2004, 02:39 AM
TylorWeaver's Avatar
I have a question in regards to installing an aftermarket Tachometer.
I will be purchasing a C2 Auto Meter Tach w/ shift light.
I do know that our cars are distributorless, and run of DIY or something, and that if you wanted to install a tachometer(aftermarket) you'd have to purchase a module to convert stuff..
Well, my concern is, I already bought the Tach., and I'm stuck...lol
I knew I was going to run into this problem, but they're ARE ways around this..
I believe that MSD makes a module to plug a big-face tach into, that then plugs into your ECU or this *3 port..
Please.. HELP!!! :twisted:
Thanks!
-Tylor
TylorWeaver is offline
Old 12-07-2004, 07:59 PM
SUPASCIONXB's Avatar
I installed an autometer sport comp in my box with no problems I just hooked the tach lead into the data link connector # 3 { black wire } the only thing that had to be done to the tach was the yellow and brown wire loops in the tach had to be cut as per the autometer instructions so it would work for our 4 cyl setup.
SUPASCIONXB is offline
Old 01-24-2005, 05:17 PM
lebshiff21's Avatar
Any chance we could get a similar breakdown for the tC? Specifically the radio harness? Been searching forever and can't find anything, and they're not the same!
lebshiff21 is offline
Old 02-03-2005, 06:44 AM
bB86gts's Avatar
most of the info is the same across the board, only difference are between the models are in the bcm.....all ignition and radio wires should be the same..
bB86gts is offline
Old 04-30-2005, 05:44 PM
o5scionxb's Avatar
uuuh...is the parking lights wire positive? trying to make junk light up off it, would really help to know...or I could just plug in and find out
o5scionxb is offline
Old 04-30-2005, 05:45 PM
o5scionxb's Avatar
and 12volt? oops
Old 06-30-2005, 03:36 PM
wedgiesaurus's Avatar
this thread is my hero. thank you.
wedgiesaurus is offline
Old 08-29-2005, 12:42 AM
blackedoutxb's Avatar
what is the blue and white wire on the radio harness?
blackedoutxb is offline
Old 09-08-2005, 01:06 AM
hotbx's Avatar
wow great info Inazuma - definitely a keeper
would you happen to know how i would hook up the halos and leds lights from a projector headlight to the existing turn signal wires? i'm not that techy but i'm sure i would have to splice them onto the existing turn/parking signal wires. any info/instrux on that would be appreciated. thanks.
hotbx is offline
Old 01-26-2006, 12:37 AM
Xbilly's Avatar
Where do I find all these wires with these colors?
(what harness(es) do(es) this apply to?
Xbilly is offline
Old 01-26-2006, 08:15 AM
Founder
scionlife's Avatar
Look at the "location" column of the chart, it tells you where each wire is located.
Old 01-26-2006, 04:37 PM
Xbilly's Avatar
WoW, don't I feel like a freaking retard.
hah.
Xbilly is offline
Old 04-11-2006, 08:43 AM
zinker's Avatar
if anyone looks by tomorrow or today I guess I got a line out converter for the stock HU so I can run my subs which wire is the remote the radio 12v blue/yellow or radio switch gray
zinker is offline
Old 04-12-2006, 06:11 AM
invisible21's Avatar
the 'radio switch' wire is the one you'd use for a remote turn on.
Also even though this thread is old, I thought anyone who reads it should be thanking DEI directechs bc that is where Inazuma copied it from. I work in an install bay and we get our wire info from the exact same place and they look exactly like that.
invisible21 is offline
Old 06-08-2006, 10:36 PM
hobby8691's Avatar
Default Radio Mute Button
Has anyone re-wired their steering controls to include a mute button? I would like to have my mode button become my mute control. I know there must be a pin on the back of the radio that will provide a remote mute - anyone explored this?
hobby8691 is offline
Old 07-08-2006, 03:36 AM
caddnima's Avatar
My first post here.
For those who are looking for tC.
Here you are.
This is a link from Bulldog Alarm System Wiring Diagram.
http://www.directwholesale.net/diagr...8403&MakeID=51
___
caddnima is offline
Quick Reply: Scion xB Wiring Colors
