Question: TRD Performance Shocks
Old 08-31-2016, 09:19 PM
traskw's Avatar
Default Question: TRD Performance Shocks
When using stock springs with the TRD Performance Shocks is the ride height maintained?
2005 Scion xA
traskw is offline
Old 09-01-2016, 01:24 PM
HATEnFATE's Avatar
The Shocks do not set the ride height. The springs are responsible for that.
HATEnFATE is offline
Old 09-01-2016, 01:50 PM
traskw's Avatar
Not always the case. I've purchased Koni Yellows in the past and the struts themselves were shorter than stock, thus dropping the ride height even with stock springs.
traskw is offline
Old 09-01-2016, 05:08 PM
HATEnFATE's Avatar
The only way they should change the ride height is if they are fluid filled instead of gas filled and you're coils are tired....
Old 09-01-2016, 05:48 PM
traskw's Avatar
Or if they are physically shorter. Which the Koni are. BTW, the best way to adjust ride height is not by springs, if we were talking full coilovers, you would ideally want to adjust the length (better coilovers do this), not the springs. The springs should be adjusted for preload, not ride height.
traskw is offline
Old 09-01-2016, 05:53 PM
traskw's Avatar
Perch height can also effect ride height on struts (creating more or less preload). I was looking for someone who has tried them and compared the length, since the length of the strut is the best factor to consider in regard to ride height.
traskw is offline
Old 09-01-2016, 08:50 PM
HATEnFATE's Avatar
You are correct in the idea that the spring perch could be moved to adjust the ride height without changing the spring, but on an xA/xB the rear uses shocks, not struts, therefor making a strut with a lower perch would only lower the front, and to adjust the rear you would need a short coil, which would completely throw off the bias in relation to the front.
So back to the OP, no, it shouldn't change the ride height on an xA/xB, because the rear is a shock and the ride height is fully dependant on the coil.
FaridTC2
08-21-2016 09:26 PM
FaridTC2
07-22-2016 10:16 PM
sciontist75
07-20-2016 03:56 PM
zoomclick
Scion xD Suspension & Handling
07-02-2016 01:40 PM
Quick Reply: Question: TRD Performance Shocks
