Airlift Compressor Fuses Question viair 380c
Old 08-29-2005, 05:59 PM
Spider13's Avatar
Default Airlift Compressor Fuses Question viair 380c
For the last week I have been battling the fuse for my compressor. For 6months it ran fine with a 15 amp blade fuse, suddenly last week it blows this fuse after about 10 minutes. Airlift says that it should have a 30amp, even sent me a copy of the directions to prove their point. So what is everyone else running?
Spider13 is offline
Old 08-29-2005, 10:31 PM
sciondrgn's Avatar
One Vair 450 with 50 Amp Blade fuse / Using Viair Pressure switch
sciondrgn is offline
Old 08-30-2005, 12:03 AM
hamads's Avatar
i believe the 380 draws more than 15 amps at its peak..u should run a 30 amp fuse b/c the higher psi the compressor is working at, the higher amperage draw..also check your connections and make sure your ground is good
hamads is offline
Old 08-30-2005, 12:35 AM
Spider13's Avatar
I rewired everything over the weekend and it still blows 20amp fuses in about the same time. I mainly posted here becuase airlift never seems to have the same answer twice. Thanks for the help guys, I'll throw a 30 in there and see what it does.
Spider13 is offline
Old 08-30-2005, 01:34 AM
Sittin_Pretti_Box's Avatar
I use a viair 450, and I think I use a 20 or 30 amp fuse. Are you running a relay?
My bro's truck kept blowing fuses and he uses a Viair 450. His relay was the problem.
Sittin_Pretti_Box is offline
Old 08-30-2005, 02:59 PM
BrianxB's Avatar
I used a 40 amp AGU fuse with 8awg wire for mine.
BrianxB is offline
Old 09-01-2005, 07:34 AM
hamads's Avatar
sittin pretti mentioned something i forgot to add,...RELAY!!! i dont think u wanna burn a 200 buck compressor. make sure u wire the relay correctly though, search anywhere online for the wiring diagram and you should be set
hamads is offline
Old 06-13-2011, 12:30 AM
Ricersux's Avatar
Im having issues blowing fuses with a dual 380c setup...all of a sudden ive started blowing 40amp fuses...any ideas? Like im blowing 4 fuses a day!
Ricersux is offline
Old 07-12-2011, 04:44 PM
Wagonistas
randode's Avatar
for 2 comps you need to run a relay, and a 60 amp fuse, also the wiring should be at least 8 gauge. for a single comp, use a 30 amp.
randode is offline
Old 07-13-2011, 05:00 AM
eight08customs's Avatar
if you have an amp meter disconect one compressor at a time and let run and take amps.. you may have to much draw or maybe a bad compressor.
http://www.facebook.com/AirRexAirSuspension?sk=info
http://airrex-usa.com/
eight08customs is offline
bootlgr
01-26-2016 01:22 AM
Greg S
05-28-2015 12:46 AM
Scionxa180
03-13-2015 04:39 AM
TotalChaos
13
02-04-2015 10:24 PM
xBassist
9
01-21-2004 07:34 PM
Quick Reply: Airlift Compressor Fuses Question viair 380c
