Brand new shocks/struts Pulls hard to left?!
Old 06-18-2006, 09:26 AM
N.G.S.O.
savage's Avatar
Default Brand new shocks/struts Pulls hard to left?!
I just had brand new Koni sport shocks/struts installed. I've had Goldline coils on it since Oct '05. I also had a strut bar put on with the new shocks/struts.
The car's alignment seems great...stearing is in-line with the wheel dead center. My problem is that the car is pulling pretty hard to the LEFT when I let the stearing wheel go! Every time no matter what the road surface is like. It's so bad it will damn near change lanes.
I'm lost???
savage is offline
Old 06-18-2006, 09:30 AM
OldYeller's Avatar
DID you get the car alligned after the work? It is something you have to do.
OldYeller is offline
Old 06-18-2006, 09:37 AM
N.G.S.O.
savage's Avatar
I figured that was understood...yes it was aligned with shocks/struts/strut bar install.
savage is offline
Old 06-18-2006, 11:17 PM
jct
jct's Avatar
might want to check your disk brakes...
jct is offline
Old 06-18-2006, 11:29 PM
ScionERA
deviousXA's Avatar
Did they Set The Caster Correctly?....some hack alignment guys dont take the time to set it because you cant set it in real time you have to make adjustments then re calibrate everything then see where your at then do it again if it isnt right.....they might have just done camber then toe and go.....then id look into tire condition/wear patterns....youd be suprised how much a uneven tire will yank a car thats set correctly
deviousXA is offline
Old 06-19-2006, 06:45 AM
N.G.S.O.
savage's Avatar
Brake pads are about 6 weeks new.
I'm gonna try swapping the two front tires & see if it pulls RIGHT after that. I got the tires back in Oct of last year.
Thanks
savage is offline
Old 07-03-2015, 01:05 AM
greenninja5150's Avatar
Default well?
Thanks
OK, what was the problem? If you learned something please share it. It might help someone else out.
greenninja5150 is offline
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
my06tc
06-25-2015 12:18 AM
nightfox915
04-17-2015 07:06 PM
ninoTc
01-26-2015 05:22 AM
Quick Reply: Brand new shocks/struts Pulls hard to left?!
