VSC and Traction Control Lights On, No faults.
2006' Scion xB 170k, 5speed .
No CEL , or Fault Codes. Just the VSC, ABS and Traction Control Off is illuminated.
I do believe a tie-rod is going out on my passenger side .
A Jeep compass had same issue , new upper and lower control aims were changed and an alignment was done. That had fixed the VSC Traction Off lights issue in that case.
I was also reading it may be the angel sensor / clockspring , if so how should I go about test/reset ?
Ideas?
Ideas?
If those lights are on, first thing I would do is see if the brake fluid is low.
If the brake fluid is not low, there ARE codes.....you just don't have the proper diagnostics tool to see them.
You need a tool which is able to "Scan All Modules".
Ideas?
Ideas?
Nosoupfuru
11-05-2020 03:51 AM
Subcompact Culture
08-08-2009 05:29 PM
bluexbox916
10
07-23-2008 02:40 AM
syring65
08-29-2007 01:04 AM
