Easy Street Rear setup
Old 08-10-2007, 03:24 PM
AstroJR's Avatar
Default Easy Street Rear setup
For all you that have the rear easy street setup .. it says i have to grind the nub off the spring plate .. is this 100% neccessary? Thanks in advance
AstroJR is offline
Old 08-10-2007, 04:54 PM
EZ-BAKED's Avatar
Default Re: Easy Street Rear setup
I dont know anything about the easy street set up but check this out before you cut anything.
https://www.scionlife.com/forums/vie...789&highlight=
EZ-BAKED is offline
Old 08-10-2007, 05:11 PM
TerribleTed's Avatar
You need to trim away a small portion of the upper spring perch so that the easy street bracket cqan sit flush to the subframe. The area trimmed, from looking at it, I personally feel that the factory springs could be reinstalled just fine without this little bit of upper spring perch. It would not be terribly hard to fabricate some steel to replace the removed section if it came to that. I have easy street air and I do not think I will ever end up reinstalling springs anyway
TerribleTed is offline
low_down_xb's Avatar
yes you have to cut it, there is no way to get around this, if not you cant mount the bag bracket, i have the same set up
low_down_xb is offline
Old 08-10-2007, 11:41 PM
BagNasty's Avatar
Ted is dead on it!
BagNasty is offline
Old 08-13-2007, 02:20 AM
AstroJR's Avatar
thanks guys i got everything in and ill have pics to follow as soon as i get my front camber bolts in .. thanks again
AstroJR is offline
my06tc
06-25-2015 12:18 AM
carid
02-12-2015 11:54 AM
NewBox06
02-03-2015 04:02 AM
evolving_machine
01-13-2015 08:04 PM
TheTripleC
01-04-2015 06:46 PM
Quick Reply: Easy Street Rear setup
