Echo front struts and bumpstops
Old 04-27-2011, 06:04 AM
Glowbox's Avatar
Default Echo front struts and bumpstops
Im lowered right now on s techs (2006 xB) with 215 35 18 tires and will be installing the echo front struts for the extra 1/2" drop up front
My question is do i need to cut the bumpstops at all when using the echo struts?
Glowbox is offline
Old 04-28-2011, 01:23 AM
ChampionJeep's Avatar
I am running df210's with the Echo struts. I cut mine in half when I installed the struts.
ChampionJeep is offline
Old 04-28-2011, 03:47 PM
StealthBox's Avatar
I cut mine in half also when I installed mine..
StealthBox is offline
Old 04-28-2011, 04:55 PM
Glowbox's Avatar
does the cutting just allow the suspension to travel farther? and would it be bad if i left them the way they are?
Glowbox is offline
Old 04-29-2011, 04:11 AM
You get a little more suspension travel. On certain bumps you might bounceoff the bumpstop. Just cut them. I think even in the instructions it tells you to trim the bumpstop.
airmankevin1
02-14-2018 01:23 PM
xa007xa
02-22-2015 02:56 PM
AxRxP
01-25-2015 08:40 PM
757_BRDFLY
01-09-2015 12:29 PM
anarvan
10-31-2003 01:14 PM
Quick Reply: Echo front struts and bumpstops
