Help please with 2005 xB Balljoints/Control arm!!!
Old 06-21-2008, 07:14 PM
tlzook's Avatar
Default Help please with 2005 xB Balljoints/Control arm!!!
Stealership says that the lower ball joints are not a "serviceable part". Telling me that I have to replace the WHOLE lower control arm, $300.00 part, per side. I have a nice "clunk" coming from the driver side front, checked the upper strut nut, tight, and mount, changed out the sway bar end link bushings,
there seems to be a little "play" at the ball joint. I thought that the fronts were similar to the Echo's but I can't find anyone local or online selling a ball joint for the xB. I'll take "blame" for "railing" on-ramps and cloverleafs primarily "loading" the right front end... INPUT needed please.
_____
tlzook is offline
Old 06-21-2008, 11:22 PM
Music City Scions
bB2NER's Avatar
Search wwwcar-part.com for a yard near you with a used xA or xB and get what you need cheap (prolly under 100 bucks).
bB2NER is offline
Old 06-24-2008, 02:54 AM
tlzook's Avatar
Thanks, worth a shot SC
tlzook is offline
Old 06-24-2008, 04:13 AM
TheCCBox's Avatar
You have to replace the whole front for a lower ball joint that is ___ lol. I stoped taking my xb to the stealership because thats all they do they give you a warrenty and dont even let you get the warranty work for free lol.
TheCCBox is offline
Old 07-03-2008, 04:11 AM
Music City Scions
bB2NER's Avatar
Have you had any luck in finding the parts you need?
bB2NER is offline
Old 07-06-2008, 07:55 AM
IV ACE
bB384's Avatar
1st gen xB's use the same control arms as the last generation MR-S.
bB384 is offline
Old 07-06-2008, 08:30 PM
Music City Scions
bB2NER's Avatar
And Echos I believe.
bB2NER is offline
Old 07-16-2008, 02:05 AM
Ford_Falcon's Avatar
What a coincidence. I have the same problem with my '04. Just had the wheels aligned a couple months ago. I'll be damned if I remember how it happened to mine. My xB has the same symptoms as what tlzook described. Except I'll take it a step further and note that when I'm driving down the freeway the car will momentarily veer to the side without turning the wheel. Freaky! It's a good way to stay awake while driving?!
Got a quote today for $450 for the driver side control arm. Stealership alright.
Will have to find a wrecked xB somewhere that had no front damage.
I found a part on eBay for an Echo 00 - 5/03
Just checking to see if it is compatible. It looks identical from what I can see.
Ford_Falcon is offline
Old 01-30-2009, 06:35 PM
Hey peeps,
Just an update (albeit a little late), I did find a control arm. I used http://www.uneedapart.com as one of my serch tools, and came across Mom's Auto Parts. This was about 6 months ago, but I picked up a control arm for $120 shipped. Had my mechanic install it for $50. No more clunks. Rock'n an' rolling!
Old 02-01-2009, 04:24 AM
Metro273's Avatar
^^^Nice!
Let us know how long that used one lasts!
Metro273 is offline
Old 03-13-2011, 06:06 AM
TraumaNaked's Avatar
I know this is a dead thread, but with the last of the first generation xA/xB turning 5 years old, a lot of ball joints are going to be toast sooner than later regardless of how hard we drive the on ramps.
While I can't say for sure about the 2004-2005 xA/xB, I know the 2006 has a serviceable lower ball joint. If you guys haven't discovered it, check out partsgeek.com and toyotapartsexpress.com: both of them list lower ball joint replacements. Maybe having serviceable lower ball joints is the difference between 2005 and 2006 lower control arms?
But here's the thing: why bother replacing either the control arm or the lower ball joint when Energy Suspension makes replacement ball joint boots? The rubber is going to fail way before the metal does, just lube them up good and get some more benefits from polyurethane. If you want to get nuts, drill a grease fitting from Lowes into the control arm. I've never tried or seen this done, nor do I think I'd go through the hassle, but if it doesn't work, who cares? You have to replace the control arm repairing them the conventional way, anyway.
At the next service, I have to replace my brake pads. As long as I have the front torn down, I'm going to pull the control arm and replace all the rubber bushings with polyurethane. I'll try to post an update.
TraumaNaked is offline
Old 03-14-2011, 03:25 AM
tlzook's Avatar
I kinda forgot about this. Rockauto has Beck/Arnley control arms for about 100.00/side. Mevotech is making them also as well as FEQ. All come in under $150.00/side.
tlzook is offline
Old 03-14-2011, 06:20 AM
Reactor's Avatar
Echo ball joint should work. Presses into the control arm with basic press set.
http://www.moog-suspension-parts.com...od=MOOG-K90310
Reactor is offline
Old 03-14-2011, 06:52 AM
Those are the ones I saw on partsgeek.com for around $45 plus shipping. Order the parts, grab a 6 pack and the control arm, walk into any shop at 430. Done for $60.
Old 03-20-2011, 11:11 PM
LowerLevelMan's Avatar
(^ snicker,.....been there, done that )
LowerLevelMan is offline
Old 04-16-2011, 10:17 PM
DarkTari's Avatar
You do have a shop press..... right ?
DarkTari is offline
Old 05-14-2013, 06:21 PM
phillydevil's Avatar
Anyone know where I can rent the tool for getting the bushing out?
phillydevil is offline
Old 07-10-2014, 03:16 AM
Bondo's Avatar
Can anyone provide pictures on removing any of the 2 lower control arms? I'm having the worst time tryin to figure out how to take um out!
Bondo is offline
Old 08-18-2020, 11:34 AM
Jesse2005xb's Avatar
So it is 2020 and this thread is very old but wanted to know if the ball joints out here now are able to service the 2005 Scion xB?
I purchased a ball joint and rented the tools but I am not sure the ball joint job alone will work because It may have to be the entire lower control arm.
_____
Jesse2005xb is offline
Old 08-21-2020, 03:40 PM
mrrcom's Avatar
_____
Did you figure it out? I have this control arm here and the ball joint is like press fit on a lip and secured with a clip. I think one of those cups/c clamp would work. If you can find a good price on the pair of control arms they've got the other bushings too so maybe worth it?
mrrcom is offline
Quick Reply: Help please with 2005 xB Balljoints/Control arm!!!
