I want to see what a 2.5 drop looks like before I buy Coilovers
Old 05-10-2012, 04:47 PM
hmc2261CT's Avatar
Default I want to see what a 2.5 drop looks like before I buy Coilovers
Im looking at buying Raceland coilovers, I already have a Eibach Pro kit lowering spring kit, but I want to go lower. My current drop is 1.5 in front and 1.8 in rear.
I just wanted to see some pics of an xa that has been lowered, 2-3 inches over stock. So please post pictures!
Also is it true if you max out your coil overs that the ride will be bouncy? and if I were to drop it the full three inches (maxing out the coilovers) do you think the control arms would be hitting the struts (I hear that is a potential issue)
Thanks!
hmc2261CT is offline
Old 05-10-2012, 05:06 PM
Big_Jim's Avatar
search is your friend.
Big_Jim is offline
Old 05-10-2012, 05:22 PM
itscurtsk's Avatar
view my photobucket below, im on 17s with sportline.
itscurtsk is offline
Old 05-10-2012, 05:57 PM
hmc2261CT's Avatar
Your car looks great!, I was looking on the raceland website and did not see sportline,
how far did you drop it?
Old 05-10-2012, 05:58 PM
hmc2261CT's Avatar
Wait, is that the Eibach Kit?
Old 05-10-2012, 08:08 PM
itscurtsk's Avatar
haha yea sportlines are from eibach with a 2.5 dropped, honestly if you have the money get racelands, i really want to see it on an xA because i'm saving for them. you can probably get a drop up to 3.5 inches if you remove the rear perches and helper spring.
Old 05-10-2012, 10:36 PM
hmc2261CT's Avatar
i have hear tho that if you max out the coilover kit, your suspension will actually get bouncy since you could potentially limit the travel of the shock,
Have you heard of anything like that?
Old 05-11-2012, 12:08 AM
itscurtsk's Avatar
the struts and shocks should be shorter than oem. i've been reading the raceland thread for xb1 on their forum and they don't have any complaints about being too bouncy. many of them have helper spring and rear perches removed, going half an inch lower than what raceland made it to be. ride quality does go down of course. these are racelands, half the price of the average coilovers and these don't have dampening adjustment.
Old 05-11-2012, 01:13 AM
hmc2261CT's Avatar
Yeah, good point,
one last question that i have, did you space your wheels at all, and did you roll your fenders (or do you think I would need to if i went down .2 in more front and rear from your ride height)
I really want to avoid rolling my fenders.
Old 05-11-2012, 03:00 AM
itscurtsk's Avatar
my rears are spaced out like 20mm I believe. my specs are 17 x 7 rims with 40 offset. i have to use 5mm spacers for the front to clear the calipers. you don't need to roll fenders. i still got like .5 inch left in the front and 1 inch in the rear left. if you get coils you won't have to worry about rubbing issues. i'm assuming to you have 17 inch rims too or else you'l have to make an adjustment in judging the drop and gap.
Old 05-11-2012, 03:45 AM
hmc2261CT's Avatar
yeah I have 17s too, but my offset is 45,
I was thinking on a 25 mm spacer in the rear, and that would bring me out to about half way through the 1 inch lip on the rear fender, and I was thinking a 15 mm or 20mm in the front to pull them out to almost the fenders.
But Im not sure yet, id rather get the coilovers on first and then remeasure the gap for spacers.
Old 05-17-2012, 04:11 PM
hmc2261CT's Avatar
itscurtsk, just out of curiosity, when you put on the lowering springs, did it mess up your camber? id like to drop my car 2.7 in front and 3 in the rear, and I have seen pictures of peoples alignment getting messed up.
Old 05-17-2012, 04:50 PM
itscurtsk's Avatar
springs did not change my camber. i never had on coilovers so i wouldn't know. racelands don't have camber adjustment but the more expensive ones do.
Old 05-17-2012, 05:04 PM
hmc2261CT's Avatar
yeah I saw that they did not, I guess ill just need to buy camber bolts, thankfully they are relatively cheap.
Thanks for the heads up!
Old 05-18-2012, 03:37 AM
05sciko's Avatar
i think ksport also makes top hats for the xA/xB with camber adjustments. ive seen them somewhere but ill try n find them again.
05sciko is offline
Old 05-18-2012, 03:57 AM
hmc2261CT's Avatar
Yeah If you find that that will be great.
Old 05-19-2012, 01:52 AM
05sciko's Avatar
after a quick search i couldnt find the ksport ones but if you google 04-06 scion xb cusco camber plates you can find the cusco brand. they are about $275 for the set though
05sciko is offline
Old 05-21-2012, 09:14 PM
hmc2261CT's Avatar
Yeah thats expensive, thanks for looking though!
helloninja
03-19-2018 04:50 AM
xdejablu3x
04-19-2017 03:44 PM
pdxgen2
Scion xB 2nd-Gen Wheel & Tire
03-14-2015 01:56 AM
jcraff3
02-20-2015 11:41 PM
TheTripleC
01-04-2015 06:46 PM
Quick Reply: I want to see what a 2.5 drop looks like before I buy Coilovers
