New Bigger, Better, Sway Bar Set From HOTCHKIS!
2004-2007 Scion xA / xB
Part# 22414 Competition Sway Bar Set (Available rear sway bar only #22414R)
Features:
• Front sway bar-lightweight, durable 1 1/8” (29mm) tubular steel
25% stiffer than stock sway bar - (355 lbs./in)
Greasable polyurethane bushings with cad. plated sway bar brackets
• Rear sway bar-lightweight, durable 15/16” (24mm) tubular steel
Rear bar is rigidly mounted (bolt-on) (250 lbs/in.) (No stock rear sway
bar to compare %)
CNC machined billet steel ends are TIG welded to rear bar
Premium installation hardware included
• Finished in durable gloss red powdercoating
Benefits:
• Vehicle in stock form showed excessive roll and understeer
• Replaces OEM front stabilizer bar and adds a rear stabilizer bar
• Hotchkis sport sway bars have increased stiffness, which…
•Reduces Body Roll
•Improves High Speed Stability and control
•Increases Traction During Cornering
• Vehicle equipped with Hotchkis sway bars showed neutral handling
Gain increased stability and control of your Scion xA / xB with the Hotchkis Sport Suspension competition sway bar package. Our replacement front and bolt-on rear sway bars give the xA / xB precise, balanced handling especially when carrying addition passengers. Comfortable ride quality is maintained. Additional benefit of tire and wheel upgrades will be felt due to the increased front/rear roll stiffness of our sport sway bar package. This easy to install package is well engineered for maximum performance, is powdercoated gloss red for improved durability and comes complete with installation hardware. For additional performance try our sport lowering springs #19412 for the ultimate in Scion handling and comfortable ride quality.
For more information on our NEW comp sway bar kit, click the link below!
http://www.hotchkis.net/
Features:
bar to compare %)
Benefits:
•Reduces Body Roll
To reduce the over all body roll of the xB, you want to use the full potential of the sway bars “Front and Rear”. The front sway bar improves turn in and quick steering response and the rear sway bar helps with the rotation around the corners.
I love my "Old" Hotchkis sway bar set. They made a big difference in handling and reduced body roll greatly. I can only describe the handling as precise and extremely agile now I have 7000 miles since install. (the very first time I drove the car after install as I turned right out of my buddies shops parking lot.....I nearly turned the car onto the right curb....the response was that much faster than what I was used to)
I was reading on a website that these new bars were tuned for race tires only...? These bars will be fine with regular street tires? Sorry if this is a stupid question but I am just starting to learn about the suspension/handleing of my xa so I am new. Thanks for any info.
Originally Posted by JSosa
any pictures, anywhere i could purchase?
We are working on getting them up on our site right now. But here is a link to the sale.
https://www.scionlife.com/forums/vie...721387#2721387
coffee
cause i grind so fine
I've heard understeer is stock set up on Scions and adding front and rear bars just make the understeer move to higher speed.... Adding just rear bar somewhat balances out the suspension with front factory swaybar left alone.....
Several posts on SL discuss this in depth,, do a little reSEARCH and read all you can find.
