Question: TRD Performance Shocks
Or if they are physically shorter. Which the Koni are. BTW, the best way to adjust ride height is not by springs, if we were talking full coilovers, you would ideally want to adjust the length (better coilovers do this), not the springs. The springs should be adjusted for preload, not ride height.
Perch height can also effect ride height on struts (creating more or less preload). I was looking for someone who has tried them and compared the length, since the length of the strut is the best factor to consider in regard to ride height.
You are correct in the idea that the spring perch could be moved to adjust the ride height without changing the spring, but on an xA/xB the rear uses shocks, not struts, therefor making a strut with a lower perch would only lower the front, and to adjust the rear you would need a short coil, which would completely throw off the bias in relation to the front.
So back to the OP, no, it shouldn't change the ride height on an xA/xB, because the rear is a shock and the ride height is fully dependant on the coil.
FaridTC2
08-21-2016 09:26 PM
FaridTC2
07-22-2016 10:16 PM
