quick question about the front strut top hat
Old 09-27-2008, 09:11 PM
ryuji16's Avatar
Default quick question about the front strut top hat
i have a question about the main nut at the top of the strut, the one in the middle that holds the strut rod to the top mount, the one that is a b1tch to remove because when you turn it, it spins the shaft and leaves you nowhere.
im talking about this one: https://www.scionlife.com/tech/image...ll/front03.jpg
is it safe to remove it while the strut is in the car, without removing everything first? i neglected to install a washer under it when i put my coilovers on before, and its been rattling over big bumps ever since. nothing major, its just starting to get annoying now.
thanks guys
ryuji16 is offline
Old 09-28-2008, 04:34 AM
Seven City Scions
prescottn's Avatar
Yes it is safe to remove the nut while your car is down. You would just not want to jack up the car and remove it completely.
prescottn is offline
Old 10-23-2008, 05:31 AM
Music City Scions
bB2NER's Avatar
Yep, the weight of the vehicle will keep the spring compressed. Does the washer go under the top nut? If so go for it.
bB2NER is offline
Old 10-23-2008, 09:39 PM
ryuji16's Avatar
yea, the washer goes under the nut. thanks guys, ill update when i get around to doing it
ryuji16 is offline
Old 10-23-2008, 09:47 PM
Music City Scions
bB2NER's Avatar
I'd add a second nut also to keep them tight. Mine always used to get loose after a few miles.
bB2NER is offline
Old 10-25-2008, 03:20 PM
DriverXa's Avatar
You need to use an air powered Impact Gun. It'll zip right off.
DriverXa is offline
Old 11-21-2008, 11:02 PM
ryuji16's Avatar
btw, i never did have to take out the nut... i just zapped it with an impact gun and tightened it down and it worked. thanks for the help though, the noise is gone now (what a relief lol)
ryuji16 is offline
Old 12-02-2008, 12:25 PM
mengsta's Avatar
Wow for whoever doing the install by hand, I do not understand how they could ever get that top nut off. Kept spinning the shaft on mine also. I had to bring it to a buddy to remove it with an impact gun also.
mengsta is offline
Old 12-02-2008, 11:37 PM
Music City Scions
bB2NER's Avatar
If it just spins when trying to remove it you can grip the top of the shaft with visegrips to loosen the nut.
bB2NER is offline
Old 12-03-2008, 10:41 AM
mengsta's Avatar
You dont think i tried that? haha it tore up watever i was clamping on. there isnt really a solid spot to vice grip it. Or atleast i couldnt find one. But hey i was hungover so who knows. I just dont understand why the fronts dont have the allen key slot like the rears do. Woulda been much easier.
mengsta is offline
Old 12-14-2008, 07:18 PM
Tannerb's Avatar
Impacts are the way to go to remove them, You can get an electric impact from harbor freight for like $40 and it makes anything that will spin when you take it off much easier to remove.
Tannerb is offline
Old 09-08-2009, 07:27 PM
deezelium's Avatar
I know this is an old thread but would a drill with a hammer setting work similar to an impact driver?
deezelium is offline
Old 09-08-2009, 07:49 PM
Music City Scions
bB2NER's Avatar
Maybe, but it's more about the fast snap action of the impact that does the work.
bB2NER is offline
Old 09-11-2009, 11:51 AM
deezelium's Avatar
cheers, won't hurt to try
Old 09-11-2009, 03:19 PM
sdsnybny's Avatar
Its best to loosen it while the strut is still in the car then it will come off easy.
thanks guys
Toyota Manual says they are not to be reused (wont hold ) they are cheap @ 1.50 try a new set pt #90179‑12145
sdsnybny is offline
scotttie17522
02-23-2020 08:38 AM
TotalChaos
13
02-04-2015 10:24 PM
757_BRDFLY
01-09-2015 12:29 PM
BLKTOYBOX
10
03-02-2004 08:36 PM
anarvan
10-31-2003 01:14 PM
Quick Reply: quick question about the front strut top hat
