Rear Spacers
Old 08-21-2007, 04:50 AM
xBbeatBox's Avatar
Default Rear Spacers
HELLO, all of you SuSpEnSiOn gurus out there!!! I've got a quick question for all of you. But first let me bring you up to speed.
Right now I'm running:
Stock Suspension
Damani Tech-5 18x7.5 +42 offset
Pirelli PZero Nero (M+S) 215/40/ZR18
I have some Tanabe DF210s sitting in my living room, just waiting to be put on though they probably won't see use until March or April. I am debating on adding some rear shims. If I do, it won't be until March or April when I put the springs on. My question pretty basic. How thick should/could I go without a thought of rubbing?
This is my daily driver, as I'm sure most of you are in the same boat as me. I'm afraid of putting on shims and realizing that my tires are rubbing on my fenders and seeing my fenders becoming blemished.
I'm expecting some constrasting answers so throw them at me! I've got about 7 months before they're going on anyway
xBbeatBox is offline
Old 08-21-2007, 05:27 AM
sizzlinscion's Avatar
10 or a 15 will work with out rubbing
sizzlinscion is offline
Old 08-21-2007, 01:04 PM
swartzautoman's Avatar
ive got tien s-tech, monro shocks and struts from the echo, 15x7 38mm offset.
i used 15mm hub spacers and it worked out perfect.
https://www.scionlife.com/forums/vie...=asc&&start=20
i might have been able to go with a 20mm but i just wanted it to be even with the front
swartzautoman is offline
Old 08-21-2007, 02:49 PM
burstaneurysm's Avatar
Yea... I'm running on Goldlines, 18x7.5 +42. I'm running 10mm, and I still have some space before it hits the fender.
burstaneurysm is offline
Wagonistas
Just1n's Avatar
talk to keoki @ www.ke-0-ki.com
Just1n is offline
Old 08-21-2007, 07:26 PM
xBbeatBox's Avatar
Do you have any pictures with these in place? I know the Goldlines have about the same drop as the DF210s.
Also, have you had any rubbing issues at all?
Old 08-21-2007, 07:30 PM
xBbeatBox's Avatar
I tried to check out www.ke-0-ki.com but it is under construction
Old 08-21-2007, 08:34 PM
Just PM keoki on here. He is a great guy.
Old 08-21-2007, 10:33 PM
thats how i got my spacers from.
honest dude.
Old 08-23-2007, 10:43 PM
keoki's Avatar
click da link http://www.scionapocalypse.com/forum...opic.php?t=146
keoki is offline
Old 08-25-2007, 04:48 AM
japan-air's Avatar
you should go for one ton garage spacers and 8mm slip ons. will look good.
japan-air is offline
bbsciontc
Scion tC 1G Wheel & Tire
08-19-2019 01:46 AM
scionlife
371
06-02-2015 11:00 PM
stayintrucha
04-27-2015 07:55 PM
CAtC12
12-23-2014 04:44 PM
scionara
38
02-25-2004 04:52 AM
Quick Reply: Rear Spacers
