Rear wheel spacers
Rear wheel spacers
What size spacer can I put on the rear that when I tighten down the lug nuts on to the spacer the will be flush with the spacer,I am trying not to have to cut my factory lugs ,will a 1" do the trick so when I tighten the nuts down the wheel will fit flush on to the spacer and the lugs that are built in to the spacer I can then tighten down to my wheel ,can anybody understand what I want to do and help thx
Music City Scions
One inch spacers are what I ordered for the Shadow Mica. They come with lugs that should be countersunk flush into the spacer so the wheel sits true.
They will be here by Monday so I'll keep you posted how well they work.
Music City Scions
I did! The 1" spacers that have countersunk holes with studs come with the lugs needed to mount the spacer using the oem studs. They are also hubcentric.
These are the spacers on ebay.
2X Hub Centric Wheel Spacers 4x100 12X1.5 (54.1 Hub) 25MM 1 Inch JDM NA NB
Mine just showed up and can't wait to get them installed soon.
