Still high
Still high
Anyone with tein s techs know how long it takes till the springs settle? I've seen pics of xb's with the same springs that look a lot lower than mine. I've had mine on for about a month now.
honestly, like a drive around the block about does it. So, after a month, you're as low as you're going to go. But, like you, I've seen where those springs are low, so maybe the install was messed up?
My Goldlines don't quite appear to be as visually low as some other pics online that I've seen.
But one thing I've wondered is this: maybe on those vehicles people are running wheel/tire combos that are larger than stock, so the tires fill out and reduce the wheel gap, whereas I'm running stock radius tires.
Dyran what size tires have you got on your 17x7s? I have 215/40s, which give a stock radius. A lot of people run 215/45, which has just about 1/2" larger radius, which would give 1/2" less wheel gap. (and actually raise the car by 1/2" too)
rvascion
11-12-2020 03:23 AM
JonnyBigBoss
09-26-2015 08:31 PM
user9430961
09-15-2015 03:16 AM
