Struts and shocks at 85K? - Scionlife.com
Reply
LinkBack Thread Tools Search this Thread
Old 08-08-2011, 04:01 AM   #1
Default Struts and shocks at 85K?
Hola Most Honorable Hive Mind:
My mechanic/tire shop is trying to convince me that my 2006 xB needs shocks and struts at 85K miles. I called the dealer and they said no way it should need them yet.
My beloved toaster does make a creaky noise when I stop in the driveway, but is stable when I step on the bumper and let go.
Thoughts? Comments? Brilliance?
beachdad is offline   Reply With Quote
Old 08-08-2011, 07:19 AM   #2
Actually stick your hand in the wheel well and touch the strut if its oily the struts blown. then you need new struts
STlTCHES is offline   Reply With Quote
Old 08-08-2011, 10:23 AM   #3
jct
jct's Avatar
^^^ that
jct is offline   Reply With Quote
Old 08-08-2011, 06:16 PM   #4
jbod's Avatar
i've got a creaky noise too, but not sure if it's the same as yours. whatever it's probably just the noise it makes turning the wheel all the way.
yeah feel if they are oily. they could be bad, and they could not be. i had a mechanic once tell me my car at the time a 99 corolla was gonna blow the f up, and explode if i didn't replace the bad o2 sensors. well i told him to go pound salt, and 50k+ miles later i finally replaced it to sell it. car stayed in one piece!
jbod is offline   Reply With Quote
Old 08-08-2011, 10:12 PM   #5
Persocon's Avatar
my xA has 86,500 of hard miles. Delivering chinese food. speed bumps, stop and go's, more time in turns than straight aways, and it's still good.
although your driving style may differ, as long as it doesn't look like one of them hondas with cut springs that keeps bouncing after a bump, or leaking as addressed above, it should be good. Checking for uneven tire wear should also tell you something. Uneven as in flat spots or bald spots in patches. Not uneven wear like the outside tread wears faster than inside tread, like in my case too many turns too fast and not enough straights
Persocon is offline   Reply With Quote
Old 01-30-2012, 02:28 AM   #6
mine is at 82k and needs a replacement
jadeT is offline   Reply With Quote
Old 02-02-2012, 01:46 PM   #7
MidnightScion's Avatar
Quote:
What kind of driving do you guys do when u need struts at such moderate milage? My xA has nearly 95K with few thousand off pavement miles. As far as I can tell front struts are going strong still...Rear is another story...RH sprung a leak..so I replaced them...
MidnightScion is offline   Reply With Quote
Old 02-03-2012, 06:45 AM   #8
Quote:
Yeah it's for the rear. I just purchased the vehicle. I noticed weird tire wear to the rear so I brought it in to my mechanic to check it.
Old 02-05-2012, 03:17 AM   #9
Default shocks
Mine is right at 109K, and they are good, will probably change out next summer just cause i like to do stuff like that in my spare time.
scioncliff is offline   Reply With Quote
Old 02-07-2012, 06:59 PM   #10
ogerdgonz's Avatar
It also depends on if the shocks are the OEM units and the car has lowering springs. A large drop would wear them out as would a heavy system or lots of cargo hauling by the previous owner.
Gen 1 rear shocks are well under $100 and easy to replace. Might be worth it for you.
ogerdgonz is offline   Reply With Quote
Old 02-11-2012, 06:32 PM   #11
Rolling on KYBs now they're pretty similar to the stock ones. Rear ones took me 15 minutes to replace. Gotta love Toyotas.
Old 02-22-2012, 01:47 AM   #12
My '05 xB has 152K on it. I am a sales rep and carry a heavy load at all times. Still on stock struts and shocks and they are fine. Good advice on checking for oil leaks and weird tire wear. 80K mileage is too soon, IMHO.
John B.
JohnnyBfromPeoria is offline   Reply With Quote
Old 03-10-2012, 10:44 PM   #13
hotbox05's Avatar
in reality shocks and struts last MUCH less than 82k that dealer who said they should still be good to go is 1 on crack and 2 not trying to make money at all.
hotbox05 is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
This iA looks really bland..but it might be AWESOME! BlingSlade Scion iA Discussion Lounge 6 10-19-2016 01:39 AM
Miles on NF210 and stock shocks? jthistle Scion xB 2nd-Gen Suspension & Handling 10 05-09-2016 10:48 PM
air lift performance struts kb1sxv Scion xA/xB 1st-Gen Suspension & Handling 3 10-22-2015 10:25 PM
tC: Lock babyfac3pn01 PPC: Wanted 1 10-19-2015 08:24 AM
xB2: BC BR Type coilovers for sale xB2 Darrenohooligan PPC: Suspension / Brakes 0 09-26-2015 08:21 AM
Tags
2006, 2007, 80k, camry, flat, heavy, load, rear, replacement, scion, shocks, spots, struts, tire, wear, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
