xB on LSD
Old 09-16-2003, 05:43 AM
sIcKsCiOnS
avus's Avatar
Default xB on LSD
alright i know the xB already has stability control and traction control, but i was thinking that maybe a limited slip differential could complement things a bit for the xB. I know Quaife makes a helical lsd for other toyota applications, does anyone know if any of those applications are a compatible match for the xB?
http://www.quaifeamerica.com/
avus is offline
Old 09-16-2003, 07:15 AM
nacy333's Avatar
The JDM spec Toyota Vitz Turbo RS comes with LSD. Since they use the same motor's I'm assuming that the LSD should work with our xBs. The tranny probably works as well...I would assume that it would just be a 5 speed but it's probably geared a little better and should be able to handle more of horsies than what the stock xB transmission can handle.
nacy333 is offline
Old 09-16-2003, 03:42 PM
DoNuT's Avatar
Positraction? =)
DoNuT is offline
Old 09-16-2003, 04:17 PM
yanges's Avatar
Default Re: xB on LSD
and here i thought you were referring to the Mixer feature on the 6 disc CD!
yanges is offline
Old 09-16-2003, 04:36 PM
its_ikon's Avatar
although a LSD is a great mod for almost any car it will not be worth the money until forced induction is put on a car. most people can't justify the cost of the part plus the install for just having an intake and/or exhaust. shops charge a lot to work and break down a tranny.
its_ikon is offline
Old 09-25-2003, 02:08 AM
2fixA's Avatar
so the cost comes in through the labor? The part runs about $800, but maybe for someone who does a serious build up the part and labor cost may be worth it?
http://www.toyota-trd.com/en/strt/d_lsd.html
same engine, but not sure how much the transmission would play into making sure something like this fits...
2fixA is offline
TheGovernmenT
09-04-2015 11:57 AM
MagneticTC
02-26-2015 06:25 PM
dgHotLava
43
08-22-2005 10:31 AM
Quick Reply: xB on LSD
