DIY-04 xA /xB Front Wheel Bearings Step by Step
Old 10-18-2011, 07:24 AM
kboehme's Avatar
Default DIY-04 xA /xB Front Wheel Bearings Step by Step
Any interest on a photo step by step on this job? I am replacing both my front tomorrow morning.
I know there isn't a write up here on this and it is quite costly if done at a dealer or shop.
____
kboehme is offline
Old 10-18-2011, 08:53 AM
frbl's Avatar
Yes, PLEASE!!
frbl is offline
Old 10-18-2011, 10:51 AM
jct
jct's Avatar
^^^ QFT!!!
jct is offline
Old 10-22-2011, 04:44 PM
bunkla's Avatar
Default I need to do it too!
I would love to see it!
bunkla is offline
Old 10-27-2011, 08:26 AM
kboehme's Avatar
Default DIY-04 xA Front Wheel Bearings Step by Step..
This job took me 2 ½ hours including the time to take pictures and to keep getting more tools. I had a lot of tools available to me that you may or may not have access to.
The auto shop on base had everything I needed so the majority of the work was done with air tools. So for starters lift the car in the air and remove the wheels.
Then remove the brake calipers, there are 2 bolts holding the piston part of the caliper. Remove those and set the pads aside.
Remove the other 2 bolts holding the caliper to the spindle and secure the caliper out of the way.
Remove the rotor; you may need to smack it on the backside with a mallet to break it free.
Mine was rusted on and I needed to thread 2 bolts into the small holes to break it free.
With the rotor off locate the outer tie rod and take the cotter pin off the bolt and remove the nut.
This is a ball joint and will require you to either press it out or give it a good whack with a mallet to break it free.
On the bottom of the spindle, the lower control arm connects with a ball joint.
Remove the cotter pin and nut and break the ball joint free.
Take the 2 nuts on the strut bolts off and leave the top bolt in until you are ready to remove the spindle.
VERY IMPORTANT take the ABS line off (this is a $200+ part to replace).
Remove the axle nut and hammer the axle through the spindle.
Now we can take the bolt out of the strut and pull the spindle off the car.
Remove the C clip from the bearing (needle nose pliers work well).
Position the spindle assembly on the press with the stud side down,
use a socket to apply the pressure to hub and press hub out.
This will separate the hub assembly from the spindle.
Place the hub assembly stud side down on the press and secure with a holding fixture.
The fixture should fit snug around the bearing itself.
Use a socket to apply the pressure to the hub and press the hub out of the inner bearing race.
Place the spindle on the press with the outboard side up. Put the inner race that was pressed off the hub over the exposed ball bearings.
Then use a socket to apply pressure to the bearing and press the bearing out of the spindle.
You should be left with a bearing, hub, and spindle. Now it’s time to press in the new bearing. There is no need to grease the bearings at all
and it will actually create problems if you grease them. Position the spindle on the press with the inboard side up.
Use a socket to apply the pressure to the outer rim on the bearing and press the bearing down until you feel it seat completely.
Install the C clip to the inboard side of the bearing.
Now place the hub, stud side down, onto the press. Set the spindle with bearing on top of the hub, inboard side up. Use a socket to apply the pressure to the inner race of the bearing and press the bearing and spindle onto the hub. Be careful not to go too far and blow the C clip out.
You should be left with a complete spindle/hub assembly. Use the same process for the other spindle/hub assembly. To re-install the spindle, seat the lower control arm stud and let the axle shaft slide into the hub. Use a pry bar if needed to apply downward force to the lower control arm to get the bolts through the strut.
Be careful not to pull the inner axle shaft out of the inner CV joint. Secure the axle nut, lower control arm nut w/ cotter pin, and strut bolts. Seat the tie rod stud to the spindle and secure with the nut w/ cotter pin. Re-install the ABS line, rotor and brake caliper and pads. Put the wheels on and drop the car down.
You shouldn’t need an alignment after this job.
Now take the car for a spin and enjoy the smooth quiet ride. I hope this will help anyone who attempts this job. Please use this as a guide and not a technical manual; every car will have its own slight differences.
kboehme is offline
Old 10-27-2011, 10:52 PM
frbl's Avatar
Excellent! Thanks much!
frbl is offline
Old 10-04-2012, 09:11 PM
mewing's Avatar
Default Front wheel bearing replacement
Thanks for taking the time to post this. Doing my 06 xB this weekend.
mewing is offline
Old 07-16-2013, 10:27 PM
jpbryant1's Avatar
My gosh, I bet a lot of people "love" you for doing this. I am going to show my husband your pics, so when my 05 xA needs it,
he will know what to do-well, he may be happy to know this OR he may not! But I thank you anyway!
B.
___
jpbryant1 is offline
Old 09-23-2013, 09:37 PM
Metalcoffin's Avatar
Nice DYI! Basically the same thing for the xB1.
Metalcoffin is offline
Old 10-22-2013, 10:52 AM
douglasinct's Avatar
Thumbs up
Thank you for posting this procedure.
Now I know....
This is a job that I will delegate to my local mechanic.
douglasinct is offline
Old 11-24-2013, 11:12 PM
Geoman's Avatar
Axle nut= bend the recessed part of nut up..then tire back on lowered down..BIG cheater bar and jump on it..lol
Geoman is offline
Old 03-28-2014, 02:25 AM
easternshorebox06's Avatar
I know it was a while ago, but thank you for the write-up. It's same as my Subaru. I've done that twice now and am looking to doing first on my xB (243,000 miles) front passenger side.
I do everything myself but press bearing out/in. I pay local shop $50 to do that. Also I break the axle nut loose before lifting wheel up all the way. that way no pressure on the axle into transmission.
Same when tightening to specs.
______
easternshorebox06 is offline
Old 04-12-2014, 11:05 AM
BManJamz's Avatar
Thank you for this. A great step by step. It showed that I can't tackle this one right now...sold my press in my last move (kicks self, quite hard )
Will be doing this one in a bit. Have 2 xAs.
____
BManJamz is offline
Old 10-17-2017, 02:12 PM
Administrator
Administrator
MR_LUV's Avatar
Excellent DIY 04 Front Wheel Bearing article.
Basically, the same for the xB 1st Gen.
Copied over to the DIY-Tech Section
MR_LUV
MR_LUV is offline
Old 07-27-2020, 12:35 PM
TheTuth's Avatar
Default I
If no access to a press you could hammer it out with the right sockets.
TheTuth is offline
Old 08-18-2020, 11:43 AM
Jesse2005xb's Avatar
Hello,
Have you ever performed a Lower Ball Joint Repair on Scion First Generation?
_____
Jesse2005xb is offline
Old 04-25-2021, 12:28 AM
Moderator
Moderator
DannoXYZ's Avatar
You might destructively remove old bearing in pieces this way. No way you're gonna press in new bearings by hammering on it.
DannoXYZ is offline
Old 03-19-2022, 11:26 PM
goodo1boy's Avatar
I have an issue with your write up.
In the disassembly section you detail removing the bearing by pressing on theINNER bearing race while tight in a recess.
In the reassembly section you detail installing the bearing by pressing on the OUTER bearing race.
It is ALWAYS recommended to press on the OUTER bearing race when such bearing is a tight fit INSIDE OF a recess.
It ia ALWAYS recommended to press on theINNER bearing race when such a bearing is a tight fit ONTO a shaft.
The primary reason for these rules is to avoid damaging bearings, a secondary reason is to establish the correct way so that it becomes a habit.
The problem with pressing out any bearing from a recess via direct pressure on the INNER race almost guarantees damage to the bearing and complicates the repair by requiring a tool switch when pressing the new bearing in by its OUTER race.
Introducing such an unnecessary change makes it very easy for an installer to ruin the new bearing when not paying close attention, or if one gets interrupted mid-repair.
It also lessens the possibility of parts reuse if necessary, as sometimes when new parts arrive they are incorrect.
goodo1boy is offline
Old 03-22-2022, 06:02 AM
Moderator
Moderator
DannoXYZ's Avatar
He's correct, you're not understanding because you haven't actually done this operation. You have to distinguish between removing vs. installing bearing.
When removing bearing, the only way to press it out of spindle is by pushing on inner race from outside inwards. This will destructively push ***** onto outer race to get it out of spindle.
You're thinking of installing bearings when you say:
Please tell me how you would push on outer-race to REMOVE it from recess in spindle.
Note this re-assembly is pushing bearing into knuckle (a recess). In which case your example...
... is exactly the same as his instructions:
This is exactly same as his final installation step of installing hub by pushing on only INNER bearing race.
DannoXYZ is offline
Old 03-22-2022, 09:08 PM
goodo1boy's Avatar
Aparently damaging bearings is not considered to be a factor here, so I have a question.
Why not press the hub directly out of the spindle bearing?
In the article, a fixture is shown supporting the spindle from the outboard side with the hub unsupported and suspended from the bearing, while pressing the inner race of the bearing along with the hub out. If the spindle's support is strong and secure enough to do that, it ought to be up to pressing out the hub directly, which might save steps and time.
Quick Reply: DIY-04 xA /xB Front Wheel Bearings Step by Step
