Custom center caps for stock steelies
I've been running steelies w/o hubcaps for a while now, and while I like the overall look the exposed lugs & hub always looked a bit unfinished.
While visiting a new toyota-specific junkyard I found a set of these center caps in a box of random caps. Turns out they are from a 1986-1988 Corolla.
However I've debadged my xB, so having logos on the hubcaps, especially the wrong logo, wasn't going to work for me. So I used a 2-part epoxy to fill the letters, then sanded that down and used some spot-putty to get it smooth, I fixed some scratches at the same time. They aren't perfect, but you'd have to be right up against them to know. hen they got a few coats of primer, and few more of a rustoleum silver that is a close match for the factory hubcap paint.
Then I installed them. They snap onto the flange of the rim right at the hub, and are nice and solidly attached. I'm quite happy with them. I'll I know the pics aren't great but the light was fading and my xB is in need of a bath anyway. Total outlay on this is about $40, including the paints & epoxy.
That's a good look, Toyota logos or not.
I've browsed old Toyota center caps on and off; I'm too lazy to hit junkyards, and they're expensive on the internet-tubes.
...then again, I gave my sister my steelies + snows since I moved to a snowless place, so it's a moot point.
I hauled stuff a few times with DF210s and it was fine.
Nice job improbcat, thanks for the idea. I am looking at other options as I have been running steelies off and on for years. The problem I've had with chrome trim rings is the constant squeaking, plus the white paint gets scratched off (not the best prep work on my part). I'm planning on finally getting my wheels powdercoated, so I'll post pics when I have everything done.
Sorry, thought I'd replied to this earlier. There probably isn't enough plastic to just sand them off, but if you filled in the ridged area with epoxy you could then sand it flat from there. Just make sure you buy a large thing of epoxy and make sure it says it is sandable once dry.
BTW it has been 6 months since I did this and all four still look fine with no cracking/flaking. Also despite the best efforts of Rhode Island potholes none of them have come loose or fallen off.
