New Tires & Rims -Steering Wheel Shakes at Highway Speed
Hey Everyone, I just had Tenzo Type C rims 17's with Dunlop SP Zr Tires installed 215/45/17. Offset 40. The guys said they used a spacer on front wheels because rim was touching caliper. My problem is steering wheel shakes when I'm going about 70. On some parts of the freeway it's fine but on others not good . It looks like they used a 1/4 inch spacer. Any suggestions? Re balance rims ,change spacer . Any suggestions would be appreciated.
Thanks
Bob
Thanks
Bob
Re: New Tires & Rims -Shimming at Highway Speeds
Thanks
Bob
Thanks
Bob
i have 215/45/17 with 40mm offset as well... and i have no spacer..and no rubbing at all.
i suggest u take it back and see what they can do to adjust it. shaking of rim is not normal and can be a safety factor.
bobby, see if it is balanced in two places.
Crappy wheel mounting places will balance the wheel in one location
Good places will balance the inside AND the outside of the wheel....
I HAD THE EXACT SAME PROBLEM AS YOU!!!
Was completely fixed by having a different place balance them correctly, the inside and the outside.
Originally Posted by DJ_SpaRky
Did they install Hubcentric Rings??
If not that'll prolly fix that right up.
That's the missing piece, should be in on monday.
kleecker
Scion xB 2nd-Gen Wheel & Tire
05-22-2016 06:10 AM
Yakimaniac
Scion xD Wheel & Tire
11-22-2014 04:20 PM
Besk_one
10-18-2003 08:41 PM
