led taillights
Old 01-03-2013, 01:04 AM
terrye's Avatar
Default led taillights
i just bought new led tailight ,the reverse and turn signals bulbs did not come with them ,they call for 7440 bulbs one amber one white each side ,i put in the 7440 led bulbs and now my turn signals blink real fast how can i fix this ,should i take out the led bulbs and try to find 7440 regular bulbs, ambers are hard to find but auto zone has the white ,i have heard about resisters but i dont know were to install or were to get the rite ones ,can anybody help!!!!!!
terrye is offline
Old 01-05-2013, 10:28 PM
xBHAWK's Avatar
Default ...Hyperflash...
You could tap into the directional signal wire, and add a voltage regulator to bolt sides. I would get non-led bulbs.
See what I did.... it could not be brighter.....
xBHAWK is offline
Old 01-06-2013, 11:17 PM
xBHAWK's Avatar
Default ...CANBUS?....
There is another solution, bulbs with a resistor built-in. From e-bay:
http://www.ebay.com/itm/281020920344...#ht_3744wt_874
CANBUS is a new word for me.
xBHAWK is offline
Old 01-07-2013, 03:23 AM
jct
jct's Avatar
but can it melt the snow and ice off your tail lights?
jct is offline
Old 01-07-2013, 11:57 PM
JIMXB's Avatar
I believe LED bulbs do not generate alot of heat/much less wattage used. For you can touch them + not get burnt vs a regular bulb/higher wattage. Therefore, you will may need a snow brush to remove any excess ice/snow as always with the regular bulbs in the rear.
JIMXB is offline
Old 01-08-2013, 09:51 AM
jct
jct's Avatar
i'm too lazy to scrap the ice off it... for the fear of cracking or scratching the hell out of the tail lamps
jct is offline
Old 01-08-2013, 08:56 PM
JIMXB's Avatar
LOL, well there's always deicer spray.......
JIMXB is offline
Old 01-12-2013, 04:45 PM
jct
jct's Avatar
i'll just keep my incandescent bulbs they give off a nice warm glow to every thing
jct is offline
Old 02-08-2013, 12:54 AM
agarcia85's Avatar
Default Signal Speed
Sorry to thread hack but is it possible to to change the speed of your turn signals? I bought some Spec D tails for my 05 Tc about 6 months ago and just wondered if you could slow it down a bit since the OEM setting is kinda fast for the LEDs.
agarcia85 is offline
Old 02-08-2013, 02:13 AM
eignub's Avatar
yeah, you need to get an electronic flasher instead of a regular one. you can buy one at any car shop
eignub is offline
Old 02-14-2013, 02:35 PM
agarcia85's Avatar
interesting. where is this installed at by chance? because, if it is to complicated of a task i will just deal with what i got for now lol. still looks great the way it is.
Old 02-14-2013, 03:34 PM
eignub's Avatar
youve never installed a flasher before? its really easy ts right down with all the other fuses.
http://www.clubxb.com/forums/showthread.php?t=34942
the second post has a link to the diagrams (though you should be able to identify it easily.
he also has a link to an led flasher. but you should be able to go to any auto store and tell them you need an electronic flasher (instead of a mechanical one). then you just un plug the one in your car, and plug in the new one.
eignub is offline
Old 03-07-2013, 06:28 AM
DermalsNmohawks's Avatar
Carefull, micro$oft might sue you lol
DermalsNmohawks is offline
Old 03-19-2013, 08:50 PM
oneyozfest182's Avatar
Any idea the measurement across the inside of the back windshield? I wanna get one of the split LED bars at Advanced Auto Parts that has full red and then half split yellow to blink yellow each direction. I can't find them online anywhere but they have them at my local AAP.
EDIT:
Like these:
http://www.carid.com/universal-light...ng-345285.html
http://www.plasmaglow.com/firestorm-led-tailgate-bar/
oneyozfest182 is offline
Old 06-05-2013, 02:47 PM
scottmcphee's Avatar
Or you could get a better flasher that adds one-touch signaling, and works with any combo of LEDs... no load resistors needed. Plug and play with your car like that DIY flasher replacement thread walks you through.
scottmcphee is offline
jdmautoimports
Regional - Canada
09-24-2015 04:00 AM
Subaru86
09-14-2015 12:43 PM
SJMiller
09-12-2015 06:33 PM
Btp907
09-11-2015 11:46 PM
Quick Reply: led taillights
