AC Problem w/06 xB
AC Problem w/06 xB
I'm having an issue with my AC. It will not blow any air on any setting. I've checked the fuse and it appears to be good. I think its either one of two parts that have malfuctioned. Either the blower motor resistor or the blower motor itself. From what I've read online, if the resistor was broken, the fan would blow out air at one the speeds but mine doesn't blow air on any speed. I'm assuming its the motor that's bad. Anyone have any insight for me? Maybe I'm completely wrong and its something else entirely?
Test for power right at the blower motor if you have power then the motor is bad. If there is no power move to the resistor. If there is power at the resistor then it's not allowing power threw to get to the motor. Change the resistor. If your getting no power to the resistor then it may be the switch itself or possibly a rubbed threw wire. Hope this helps good luck
RY_TC07
07-18-2017 05:18 PM
