Running Lights not Working! Help SOS!
Old 04-29-2007, 02:09 AM
mrfuzzy4's Avatar
Location: 'Burbs Farmington Hills - go to school in Boulder, CO
Default Running Lights not Working! Help SOS!
OK, I need an answer to this one ASAP! I got Dual Halos, and they WERE running, but suddenly when i went to turn them on they did not, nor did the running lights!
The turn signals work, and the headlights and brights work, but the running lights nor the halos work! did I blow a fuse or a safety switch somewhere?
Please help!
__________________
mrfuzzy4 is offline
Old 04-29-2007, 02:18 AM
draxcaliber's Avatar
well, if you open your fuse block and find a blown fuse, you'll have an answer. what kind of halo;s did you get? if you got some cheap ebay ones, the led itself probably went out or something.
draxcaliber is offline
Old 04-29-2007, 02:21 AM
Music City Scions
bB2NER's Avatar
Do your dash lights still work when the running lights are on?
Should prolly run a relay for the halos to keep from blowing fuses and placing such a high load on the circuit.
bB2NER is offline
Old 04-29-2007, 02:23 AM
mrfuzzy4's Avatar
omg i love u... wheres the fuse box or whatever at? i got them off ebay, but they are a good kind; did a lot of research on them! wheres the box and how do i fix?
mrfuzzy4 is offline
Old 04-29-2007, 02:24 AM
mrfuzzy4's Avatar
aight, problem is idk how do run a switch.... if i blow a fuse again though i most defiantly will though....no dashes are not going on.....
mrfuzzy4 is offline
Old 04-29-2007, 02:26 AM
don't have a clue, i don't own a box, but this kinda information is all right there in your owners manual.
it is probably under the hood in the engine bay. it will be a plastic box that should unlatch and open fairly easily.
Old 04-29-2007, 02:27 AM
mrfuzzy4's Avatar
...aight ill check....
mrfuzzy4 is offline
Old 04-29-2007, 02:35 AM
mrfuzzy4's Avatar
aight i found my fuse box, but how do i see what happened? it doesnt make much sense to me (looks like a bunch of boxes ) what am i looking for/ how do i fix it? whould it help if i took a pic?
mrfuzzy4 is offline
Old 04-29-2007, 02:44 AM
your owners manual will tell you which fuse is for which circuit for your car. so you would look for that fuse, pull it out and see if the wire running through it is broken. if it is, that is probably why your running lights are out.
you might need to replace it with a stronger fuse because your halos might use more power than your original fuse was meant to break at.
i'm actually not that saavy with electronics, so you might want to talk to somebody like garage 1217, enginfineer, or squallheart, but i suppose they have better ways to spend their saturday nights.
Old 04-29-2007, 02:49 AM
mrfuzzy4's Avatar
ok thanks alot! can i get one from a dealer? and...uh... why are you in this section?.... jk but honestly thanks a ton! (what will this run me?)
mrfuzzy4 is offline
Old 04-29-2007, 02:50 AM
Music City Scions
bB2NER's Avatar
NEVER replace a blown fuse with a larger one!!! That is good way to start your car on FIRE!!! Replace the fuse with the right one and put the halos on a relay triggered by the running lights. Easy fix bro.
bB2NER is offline
Old 04-29-2007, 02:54 AM
Originally Posted by mrfuzzy4
OK, thanks a lot! can i get one from a dealer? and...uh... why are you in this section?.... jk but honestly thanks a ton! (what will this run me?)
Any auto parts store, maybe even Radio Shack.
I'm just all over Scionlife, regardless of forum, I just peak in on interesting sounding topics
or things I don't know about because who knows, I might even learn something.
Also, you did say the subject was an SOS, so it sounded like you wanted some urgent help.
__________________
Old 04-29-2007, 02:58 AM
mrfuzzy4's Avatar
whoah! ok thanks for the fire warning! apperently their are spare fuses, so ill just use one of those..... and ill get a relay tomorrow, but idk how to run it to it,,,, could i run it to the factory fog relay?
mrfuzzy4 is offline
Old 04-29-2007, 03:03 AM
whoah! ok thanks for the fire warning! apperently their are spare fuses, so ill just use one of those..... and I'll get a relay tomorrow, but idk how to run it to it,,,, could i run it to the factory fog relay?
So was that actually the problem then? Oh, and sorry for giving you advice that might of turned your xB into a hot Box.
__________________
Old 04-29-2007, 03:09 AM
mrfuzzy4's Avatar
im not sure... things look PRETTY funny there.... give me 5 minutes.... ill see if i can find it. the manual shows me another fuse box, but i cant find it.... no worries i dont need it.
mrfuzzy4 is offline
Old 04-29-2007, 03:37 AM
Music City Scions
bB2NER's Avatar
Use the running light circuit as a trigger for the relay and give the halos there own fused power source straight off the battery. This method insures you won't pop another fuse. Most relays have the terminals labled so it should be easy. Did the halos tell you how much current they would draw? You could go 1 size up in fuses like a 15 amp instead of 10 amp for example but that would be all.
bB2NER is offline
Old 04-29-2007, 04:08 AM
mrfuzzy4's Avatar
can i actually go a size bigger? i dont think it draws too much power, and no it didnt tell me how much power.... ill update this with pics tomorrow of my headlights, for all you guys! btw it was a 10/red fuse that was blown, and i didnt have a spare... but my moms toyota highlander doesnt need a horn so i took hers! all better! i am not sure about how that relay thing your talking about would work.... sorry im not really savvy with electronics.... i just like toying with em. so let me know how that relay would work.... if you could word it differently, or explain w/ pics that would be very helpful! kk so everything is fine! seriously i gotta give a big hand to the SL community for reacting so fast... and flawlessly! kk thanks!
-Noah G
mrfuzzy4 is offline
Old 04-29-2007, 04:11 AM
Music City Scions
bB2NER's Avatar
Just don't be tempted to go bigger than a 15 one tho. If it pops def go the relay route. Glad to help a brother out!
bB2NER is offline
kiss_tc
Scion tC 1G Aero & Exterior
12-15-2008 08:24 PM
neworldOZ
01-01-2008 09:30 PM
WVscion
10-30-2007 01:58 AM
jimmy-buffett
11
03-04-2007 08:30 PM
jman6785
01-09-2007 06:08 PM
Quick Reply: Running Lights not Working! Help SOS!
