VSC/Trac Off/Check Engine Light came on
Old 11-22-2006, 06:56 PM
IBJanky's Avatar
Default VSC/Trac Off/Check Engine Light came on
I have a 2006 xB automatic, bone stock. Last week the VSC/Trac Off/Check Engine lights came on. At first I thought I didn't tighten the gas cap enough so I reset the ECU, re-tightened the gas cap and the lights went away. A couple of days later the lights came on again, so I dropped it off at the local Toyota dealer.
They scanned the codes and these were the codes they came up with:
P0012
C1201
According to the invoice, they found that the VVTI controller (timing gear assembly) was stuck on the lock position. They had to remove the engine head cover, remove the camshaft and replace the VVTI gear assembly.
I had to leave it there for a few days because they had to special order the parts.
I picked up my box this morning and so far so good.
I didn't get charged since it was under warranty.
My xB only has 18,129 miles btw
Just thought I'd share.
IBJanky is offline
Old 11-22-2006, 08:25 PM
shorberg's Avatar
you are the 5th person i have seen with this . . .
shorberg is offline
Old 11-22-2006, 08:43 PM
cherryBox's Avatar
make that the 6th.
cherryBox is offline
Old 11-23-2006, 03:38 AM
SheDrivesA_BSPbB's Avatar
oh sh*t..that's probably what's wrong with my xB too, but my car is manual..im getting annoyed seeing those lights on everyday...
i'll have the dealership check it out once i'm due for an oil change...which is soon
SheDrivesA_BSPbB is offline
Old 11-23-2006, 03:59 AM
TOCC
jwaj2002's Avatar
I wonder if I need to worry bout this
jwaj2002 is offline
Old 11-23-2006, 04:14 AM
LVBoxman's Avatar
Mine did it too but after I reset the ECU by pulling the fuse and it went away and has not come on since I hope it stay's off too. I had less than 600 miles on mine when it happened now I'm up to 3000
LVBoxman is offline
Old 11-24-2006, 06:19 AM
i reset the ECU too..it didn't go back on for a while..but then out of no where it came back on...
im taking my car in soon...
Old 11-24-2006, 01:13 PM
kewlbox's Avatar
Mine started to do that at around 30,000 miles.After reseting ECU around ten times i took it to the dealer, and mine was with the cam gear also.
That was about 10,000 miles ago and so far it is still good.
kewlbox is offline
Old 11-27-2006, 02:08 AM
oin
oin's Avatar
Default dash lights / VVTI cam-timing sensor
same thing happened mid November to mine, just hit 28,000 miles, all fixed under warranty, but it did take a few days ............it had been running ok but just seemed a little less powerful just days before the lights came on.............my brother-in-law scanned it at his shop and found the codes, computer told him the timing was retarded
oin is offline
Old 11-27-2006, 02:23 AM
TOCC
jwaj2002's Avatar
see thats why I bought the extended warranty
jwaj2002 is offline
Old 11-27-2006, 02:34 PM
Big_Kokujin's Avatar
My light comes one too, but when i hit big ___ water puddles at like 40...
Big_Kokujin is offline
Old 12-01-2006, 03:54 PM
MikeTheMountain's Avatar
Same problem here, I'll be taking my box in this weekend for her 30K service, I'm going to bring in your post to show them. I'll let everyone know what happens.
A few others have posted about this issue as well, here's a thread I started with links to more:
https://www.scionlife.com/forums/vie...416&highlight=
Good luck!
M
MikeTheMountain is offline
Old 12-02-2006, 09:19 PM
ifeldwn02's Avatar
i have a question for why would you keep reseting the lights or not pay them any attenyion when it is in warrenty and they will fix it
and the c1201 is a generic code for the most part just saying there is a malf
ifeldwn02 is offline
Old 12-07-2006, 12:16 AM
ecxb242's Avatar
Mine came on today...I was sitting idle during lunch and felt the RPMs go way low. When I looked up I noticed they were on...I'll be taking mine in as well since I just hit 33k...
ecxb242 is offline
Old 12-07-2006, 01:01 AM
GROUNDED's Avatar
why bother to reset the pcm if its underwarranty? take that **** to the dealership and make them fix it.
GROUNDED is offline
Old 12-07-2006, 03:40 AM
madmaxbb's Avatar
Um just curious out of all of you that had this problem what kind of oil do ya use regular or sinthitic :o
madmaxbb is offline
Old 12-07-2006, 09:32 AM
ecxb242's Avatar
Regular...
ecxb242 is offline
Old 12-07-2006, 02:51 PM
djmesican's Avatar
i use mobil 1 w/ a toyota oil filter.... is that a bad thing? my check engine light hasn't came on. i barely hit 16k miles in my 05 Auto. hmm. i hope this doesn't happen to mine. if so i'mr eady for it. i have 80k mile warranty though. hehe.
djmesican is offline
Old 12-08-2006, 09:23 AM
ecxb242's Avatar
Strangely enough...they all went away yesterday...no more lights!!!
I'm still bringing it in for my 30k checkup however next week...
ecxb242 is offline
Old 12-08-2006, 10:58 PM
bBsactoguy's Avatar
Honestly, I think this light comes on with those folks who have an intake. The sensor becomes dirty and you just need to clean it.
I had this problem back in summer time and I desperately searched the site for help.
Low n behold, all you need to buy is an electric contact cleaner. You can purchase it in your radio shack, FRy's, or tiger direct.. what ever is clever.
I sprayed the lil uvula looking object, and all that dirt came right off... good as new. Just to be safe I let it dry for like 10mins before putting it back into my intake...
Solved problem.. I think I made a thread of my journey of this hehe...
bBsactoguy is offline
Quick Reply: VSC/Trac Off/Check Engine Light came on
