2013 xB Balance Shaft bearings gone
Old 02-01-2017, 04:03 AM
Sci13xb's Avatar
Default 2013 xB Balance Shaft bearings gone
so I have a problem my 2013 xB has been burning oil, b4 my oil change was do. so I would add about 2qt when it need it. About 2 days ago I noticed my oil light flicker so I check my oil and nothing . This time it was strange I had just added 2qts 2weeks prior so I start to look online to see if anyone has had this problem and I found out there was a problem with older models. I saw some where that Toyota had fixed this issue by changing out the piston ring on the new model. so I went ahead and just did the oil change instead but now the was a nose coming from the bottom of the motor so I took the oil pan off and the balance shaft bearing are gone can I just leave it of or is there something I have to do I would put it back with new bearing but one was so bad that it shave of some on the top and I don't want to take off the whole housing any suggestions I don't want to take it to the dealer because my car has 79k and they will rip me off thanx guy in advance
Sci13xb is offline
Old 02-01-2017, 07:28 PM
Greg S's Avatar
You'll need to plug the oil passage, but yes you can just remove them.
Here is a DIY from Toyotanation for doing it;
DIY: Remove your balance shafts - Toyota Nation Forum : Toyota Car and Truck Forums
Greg S is offline
