tC header does NOT fit
Old 09-02-2007, 03:13 AM
Team No Limitz
NoLimitzBuilt's Avatar
Default tC header does NOT fit
SO I got a Strup header sent to me to test this weekend. I took the factory one off this morning. Put the strup one on. I must say, I LOVE the look of his header. I had the same one on my tC. But back to the post. The bottom S pipe section is different on the xB2 then on the tC. I will post some pics of it later tonight or tomorrow. The bolts dont line up and never does the angle that the two peices match up.
NoLimitzBuilt is offline
Old 09-02-2007, 06:25 AM
ScionFred's Avatar
So it physically fits in the engine bay but requires a custom S-pipe?
ScionFred is offline
Old 09-02-2007, 09:29 PM
Team No Limitz
Here is the pics of it.. Yes it fits in the engine bay with no issues. Just the pipe does not line up. I am going to mess with it here in the next day or two and see if I can make the S pipe.
Old 09-02-2007, 09:32 PM
tCtCtC's Avatar
its not that far off... im sure if u play with it a lil itll fit
tCtCtC is offline
Old 09-02-2007, 09:36 PM
risca369's Avatar
Now I can't tell from the angle of you pics, but it looks like there might be enough space to make a simple aluminum adapter plate.
risca369 is offline
Old 09-02-2007, 09:41 PM
987KEITH's Avatar
I think some simple fabrication and a little brute force and you'd have it fitting. But it is hard to tell from the pix.
Keith
987KEITH is offline
Old 09-02-2007, 09:48 PM
Team No Limitz
no it is not that close. The angoe of the bolts is way off, then so is the angle the two meet up. If you look at the 4 and 5 the left side is touching and the right is like a inch off. No brute force is not the key here. A new S pipe or a new header is the only way. The angles are way off in to many directions to just smash and call it good.
Old 09-02-2007, 09:51 PM
06tcdude's Avatar
u could cut and reweld the flange on the s pipe if need be
06tcdude is offline
Old 09-02-2007, 09:55 PM
Team No Limitz
Yeah that is what is coming. You just need to cut and reangle the flange for the S pipe.
Old 09-03-2007, 01:13 AM
ScionFred's Avatar
The header is sweet looking. Too bad the S-pipe doesn't match up but it's nothing a little cutting and welding can't fix. Good luck with it.
Old 09-03-2007, 01:16 AM
xIxAMxHOLLYWOODx's Avatar
not to be a jerk, but duh...
xIxAMxHOLLYWOODx is offline
Old 09-03-2007, 01:35 AM
Macavely's Avatar
it the rest of the exhaust stock?
Macavely is offline
Old 09-03-2007, 03:12 AM
Team No Limitz
Yes the rest is stock.
Old 09-03-2007, 03:12 PM
Macavely's Avatar
yea thats your problem right there. must after market headers don't line up with stock exhusts pipping. you should try going with a full header back exhaust.
Macavely is offline
Old 09-04-2007, 04:14 AM
Team No Limitz
LMAO.. have you ever dealt with exhaust before?
I have built many many cars and that might be why they sent me the header to test fit. Since other people might not know what they are doing.
You can connect a header to a stock S pipe. The tC and xB are that way. If you look around you might notice that most the time you use a header, stock mid pipe, and then out to a aftermarket exhaust. I ran a Strup header, then stock S pipe, then custom mid pipe and then to a strup exhaust.
I lost power when I went to a custom mid pipe, so I went back to a stock mid pipe.
So please make sure that you have a clue what you are talking about when you say I have a problem.
Old 09-04-2007, 04:29 AM
tCtCtC's Avatar
happy birthday :D
tCtCtC is offline
Old 09-04-2007, 06:29 AM
ScionFred's Avatar
To whom were you replying?
Old 09-04-2007, 06:57 AM
Griever's Avatar
Shouldn't cost that much to have that spipe cut, extended and re-welded. Btw that Strup header looks gorgeous! I wish I had gone the Strup route rather than DC :o
Griever is offline
Old 09-05-2007, 12:19 AM
Team No Limitz
Yeah I talked to the guy at strup today and I am going to make a custom S pipe and then send it to him to look at and see what we need to do. I cant wait to get the strup header and exhaust on this one again. He makes awesome products.
Old 11-05-2007, 09:11 PM
Team Sushi
fairladyz541's Avatar
Any updates
fairladyz541 is offline
Quick Reply: tC header does NOT fit
