Engine Reset without pulling battery terminal??? - Scionlife.com
Reply
LinkBack Thread Tools Search this Thread
Old 11-24-2007, 04:08 AM   #1
Scorpius01's Avatar
Default Engine Reset without pulling battery terminal???
There is a way to reset the ECM without pulling the battery terminal.
The EFI fuse. Just pull this fuse and you have an ECM (hard) reset without having to reprogram radio stations, or reinitializing anything, pulling the battery terminal off.
How can this be? The EFI fuse supplies power to the ECM.
Also in todays modern age Car ECM's rarely need a hard reset.
Why? That is a good question. modern ECM's have processors that already are learning how to fuel a car within a couple of miles, when mods are added, dirty MAF that was cleaned, etc...
You can connect a scan tool and see this for yourself when CEL is cleared (that effects runability), the ECM will already start to compensate once the condition that set it is rectified.
Scorpius01 is offline   Reply With Quote
Old 11-24-2007, 06:50 AM   #2
ScionFred's Avatar
Good info. Thanks!
ScionFred is offline   Reply With Quote
Old 11-25-2007, 04:46 AM   #3
mnscionxb's Avatar
thanks for the great info
mnscionxb is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Alarm Help idriveanxa Scion xA/xB 1st-Gen ICE & Interior 1 03-08-2015 01:03 PM
05xB gauge cluster, HVAC cluster, tail running lights, and headlight chime dont work missing_image Scion xA/xB 1st-Gen ICE & Interior 2 02-07-2015 08:18 PM
Help please, XB stuck idle at 3000 rpm Bakoscion46x Scion xB 1st-Gen Owners Lounge 7 01-19-2015 03:39 AM
2005 XB Loss of Power ScionRo Maintenance & Car Care 1 01-02-2015 08:54 PM
grounding kit write up bryanrx7 Scion xA/xB 1st-Gen Drivetrain & Power 1 01-01-2004 10:53 PM
Tags
batery, battery, car, ecm, engine, master, reset, resetting, scion, tarminal, terminal, toyota, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
