throttle body...
Old 10-09-2007, 01:17 AM
whitebreadbox's Avatar
Default throttle body...
i was peeking under the hood and traced a few lines back the the throttle body... it was only a quick glance, but i believe there is a line connected to a radiator line piped into the throttle body. if this is true, i understand that it helps with emmisions... but, has anyone rerouted it to allow for a cooler, more dense air charge going into the engine? if it is coolant going into it to warm the body, which warms the air, wouldn't it be the cheapest mod, assuming it doesn't trip a fault? just wondering
whitebreadbox is offline
Old 10-09-2007, 01:33 AM
JerseyTech's Avatar
look up coolant by-pass mod
JerseyTech is offline
Old 10-09-2007, 05:48 AM
ScionFred's Avatar
I was just thinking about that tonight. I've done the bypass mod before in the past but this time I'd like to do it better. I'm thinking of using a 'y' valve on either side so I can bypass the TB during the warmer months but allow coolant to warm the TB during the colder months.
ScionFred is offline
Old 10-09-2007, 02:41 PM
uberspeed's Avatar
Sounds interesting, searching now...
uberspeed is offline
Old 10-09-2007, 03:23 PM
uberspeed's Avatar
Well, seems like I won't be doing this one, rather pointless.
Old 10-09-2007, 11:20 PM
matt311's Avatar
you mean this? http://cgi.ebay.com/ebaymotors/04-08...spagenameZWDVW
matt311 is offline
Old 10-10-2007, 02:43 AM
uberspeed's Avatar
6-8 WHP!?
Riiight.
Old 10-10-2007, 04:06 AM
kezz's Avatar
similar question...Whats up with the magnets you put around a fuel line? Ive seen a couple products similar to this
http://cgi.ebay.com/ebaymotors/Scion...spagenameZWDVW
that look more performance oriented...cool looking part or valid technology?
Obviously the link above isnt "cool looking"
kezz is offline
Old 10-10-2007, 05:19 PM
ScionFred's Avatar
I doubt that a TB bypass alone would show any measurable HP gain on the dyno but it should cause the ECU to advance the timing curve a bit which could result in a small improvement in response/acceleration.
In any case, a TB bypass will surely do more than that Turbomag crapola.
Old 10-10-2007, 09:55 PM
matt311's Avatar
magnet is stupid... the TB bypass is only slightly better... in Texas im going to probably do it... ill let you know if anything is improved at all... which I doubt will.... but it cant really hurt... it dosnt get under 50 degrees here! lol...
matt311 is offline
gedster314
14
11-17-2018 02:56 PM
Blunderbuss
10-08-2015 04:56 PM
MeDizzy
10-08-2015 03:31 PM
Brently1
08-12-2015 10:54 PM
rancur3p1c
07-12-2015 07:59 PM
Quick Reply: throttle body...
