Maint Reqd light - Scionlife.com
Reply
Thread Tools Search this Thread
Old 10-22-2007, 08:13 PM   #1
Default Maint Reqd light
All,
I just turned 5k on my xB2. The maintanence light came on, and stays on. I was wondering how to turn it off. DO I have to disconnect the battery cable for a bit? I was hoping I wouldn't have to lose all of my fuel data, and am wondering if all of that will go away when I reset.. Any advice would be appreciated.
ominousinc is offline   Reply With Quote
Old 10-22-2007, 10:55 PM   #2
TerribleTed's Avatar
Not sure about the 2nd gen. Might be the same as the first gen. On the first gen you make sure that the odometer is displayed, turn off the ignition, press and hold the odometer rest button and then turn on the key, wait a few seconds and then light resets. A number of cars use similar maint light resets (my wifes Honda is essentially the same). There may be instructions in the owners manual, if not call the dealer , mine gave me the instructions over the phone.
TerribleTed is offline   Reply With Quote
Old 10-22-2007, 11:01 PM   #3
Moderator
Moderator
draxcaliber's Avatar
it is just a timer to remind you to change your oil. so everytime you change your oil, start the car while holding down the button next to the odometer and wait for a line of dash's to appear, and disapear one at a time, once that has happened, it has been reset.
draxcaliber is offline   Reply With Quote
Old 10-23-2007, 12:44 AM   #4
if it is like my old toyota which im sure it is exaclty the same, you make sure the odo is dysplayed, not the trips. turn the ignition on and hold the odo reset button for up to ten seconds. you will see 5 little dashs, keep holding the button and it will count down to 1 then 0 and reset the maintnence required light
ididntdoit5150 is offline   Reply With Quote
Old 10-23-2007, 01:12 AM   #5
sIcKsCiOnS
avus's Avatar
^^^ what they said
the reset procedure is that same on our xBs
just recently reset mine
avus is offline   Reply With Quote
Old 10-23-2007, 03:25 AM   #6
Whispaz's Avatar
i know, get an your oil changed by scion..... bye bye light
Whispaz is offline   Reply With Quote
Old 10-23-2007, 06:06 AM   #7
ScionFred's Avatar
First of all, get your oil and filter changed ASAP, if you haven't already.
Second, change the odo display to 'trip A' and turn the ignition to 'off'. Hold the trip reset button down, turn the igntion to 'on' and wait 5 seconds. The maint-req lite has now been reset for another 5000 miles
It's all on page 99 of your owners manual...
ScionFred is offline   Reply With Quote
Old 10-25-2007, 04:17 AM   #8
ya and if you are at 5000 miles i hope you have changed your oil and filter.
Old 10-25-2007, 04:40 AM   #9
I'm doing my comp. services at 3500 & 7000, then start my own oil changes at 11,000 then at 15000 and every 5k after that.
I couldn't get myself to wait for the 5k service, so ill do the first two sooner then move onto 4k then 5k.
Invertalon is offline   Reply With Quote
Old 10-30-2007, 02:19 PM   #10
JRT
what wt oil are you using the book states 0-20 w or 5-20w ?
JRT is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Brake light on passenger-side doesn't work. Turn signal is fine. xBSciontist Maintenance & Car Care 1 12-31-2016 04:54 PM
DIY - tC2 Independent Fog Light Mod Thread 2.0 SkillFreeJake Scion tC 2G Aero & Exterior 17 07-27-2015 01:34 AM
Fuse for climate control and trac control lights Green_rino Scion FR-S ICE & Interior 1 01-20-2015 02:41 AM
Sharp Halo projector fog lights by Spyder for Scion tC carid Exclusive Sponsored Sales 0 01-08-2015 12:33 PM
ABS/BRAKE/DOOR AJAR LIGHT ON, Keyless Remote Stopped VCUBoy714 Scion tC 1G ICE & Interior 2 01-05-2015 09:46 PM
Tags
09, 2005, light, lite, maint, procedure, reqd, reset, scion, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
