Torque Damper
Old 05-13-2010, 12:34 PM
Mach-box's Avatar
Default Torque Damper
I was wondering if anyone has used one for the xB. I am looking to get one. My motor rocks quite a bit. Also will one that was made for a tC work on an xB?
Mach-box is offline
Old 05-13-2010, 01:34 PM
coryjames's Avatar
you need the xb one they are diff we have a different passenger side motor mount. this will make it sound like there is a midget in your bay rubbing a file on your strut tower its far to noisy i would go with the motor mount. i mean look at this hot ness
coryjames is offline
Old 05-13-2010, 01:43 PM
Mach-box's Avatar
how much of a _____ is it to replace?
Mach-box is offline
Old 05-13-2010, 01:47 PM
streetxdreamer's Avatar
I dont think the TC one will fit as it mounts to the strut tower on the XB.
Just FYI be prepared for more chassis vibration with either the damper or the urethane engine mount
streetxdreamer is offline
Old 05-13-2010, 02:26 PM
Mach-box's Avatar
yea I figured. I think now there is too much movement in the motor.
Mach-box is offline
Old 05-13-2010, 04:24 PM
elwaylite's Avatar
Too much movement because of a certain mod, or just too much movement from the factory? Guess I'm asking for a why?
TIA
elwaylite is offline
Old 05-13-2010, 04:58 PM
Mach-box's Avatar
I think all the torque from the turbo. I would guess. The new clutch probably doesn't help either.
Mach-box is offline
Old 05-13-2010, 05:05 PM
elwaylite's Avatar
Ah, so its not a concern for a NA vehicle?
Old 05-13-2010, 05:48 PM
Mach-box's Avatar
I don't think so. But I can't say for sure.
Mach-box is offline
Old 05-14-2010, 06:22 AM
ScionFred's Avatar
Very easy unless your turbo setup is in the way like mine is. All I had to do was remove the intake piping from the turbo. Changing the MM took me about an hour if I count setup and clean up.
I'd get the GGP mount instead of the damper. If it's too stiff, Nurspec will soon be offering a softer 70A bushing for it.
ScionFred is offline
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
BlingSlade
10-19-2016 12:39 AM
Sgtfluffy16
09-30-2015 01:42 PM
JonathonK
09-22-2015 07:27 PM
carid
08-31-2015 11:17 AM
Quick Reply: Torque Damper
