Looking for better radiator and air flow
Old 08-24-2021, 04:23 AM
xB_RS10's Avatar
Default Looking for better radiator and air flow
Has anyone found a radiator that's better than the factory? I have a crap ton of heat dumping out every time I open my hood and I'd like to see if there's a better radiator to knock it down.
I've also flirted with wrestling some ducting up behind the top grill and piping it to the intake. Has anyone tried this and if so was there any noticeable difference?
xB_RS10 is offline
Old 08-27-2021, 05:56 PM
Greg S's Avatar
If you can find one, Mishimoto makes a great replacement radiator. You would need to add a trans cooler if you do put one in as it doesn't have the connections for it.
As for trying to pipe air from the upper grill to the intake, don't bother. I tried it and the opening between the radiator shroud and the hood is actually quite tight and causes too much restriction to make it worthwhile. Biggest improvement for the intake is to go with a cold air. Drops the intake temps quite a few degrees. Of course if you live in an area with heavy rain this may not be the best idea.
Greg S is offline
Old 08-27-2021, 06:08 PM
drizzoh's Avatar
The heat is probably generated by the motor/exhaust and not the radiator directly unless it is faulty. But if the vehicle is not overheating there's probably nothing wrong.. it is expected that the engine bay will be hot when you open the hood after the vehicle has been running lol. Not saying an upgraded radiator will not be beneficial.. but not sure it will help whatsoever with this specific under-hood-not-making-it-hot issue.
drizzoh is offline
Weapon-R
81
02-25-2013 07:24 PM
THansenite
08-13-2008 06:53 AM
syring65
06-13-2007 08:43 AM
web
12-09-2006 02:53 AM
KCTTC
11-17-2006 04:15 PM
Quick Reply: Looking for better radiator and air flow
