resonator replacement....
http://www.jegs.com/i/Magnaflow/642/54306/10002/-1
would this work good in place of the stock torpedo causing such flat tones
non-turbo cars still require a decent amount of back pressure.
people think they are doing their NA car good when they throw 2.5"+ exhaust tubing on thier car, and a bigass 4" muffler.
all thats going to do is lose you power. Your suppose to just upgrade slightly from stock if your going NA as opposed to turbo, because to much airflow causes a loss of power, if you stay around the 2" range, there will be no harm, because unless you go any smaller than stock, your still garunteed your standard horsepower
Team XcelsiA
Team Sushi
well i am gettin back pressure if you belive me or not or else i would've had not gotten the piping my brother in law works at a muffler shop and has experiance with this
oh i have alot of exhaust work on my new b. from the header back it is 2.5 to the spipe that is not mandrel bent so it has some tights spots. to the resonator it is 2.5 after the resonator its like 1.75 on. the only stock piece of pipe i have on my car is the rear spipe or cross over pipe. i left it for some back pressure in the mean time till the turbo gets slapped on. here is how it sounds with a high flow cat inplace of the resonator, and a trd axle back with the strup header.
http://youtube.com/watch?v=XtaHAfARuEI
Originally Posted by SoCalXB2
oooorrrrr you think you have no issue heh. 2.5" is really big for a non turbo, probably mostly stock car. (intake doesnt count)
Team XcelsiA
Team Sushi
::sigh:: im not going to sit here and argue with you.
Ive been a performance tech for coming up on 3yrs now, so atleast in the end i know what im talkin about.
hope this helps with some of the debate. seeing that this engine has VVT and constant fuel monitoring, some of the issues won't apply. lets keep it friendly. we're all driving the same car and want insight from others to make it that much better for the individual driver.
http://www.flowmastermufflers.com/backpressure.html
riccochetrabbit
19
08-30-2005 07:03 AM
