DIY Strup Exhaust
Old 02-14-2008, 02:50 AM
Team No Limitz
NoLimitzBuilt's Avatar
Default DIY Strup Exhaust
Here is a quick write up on how to do it your self along with the pics
First you need to jack the rear of the xB and support it in jack stands. Then you will need a 14mm socket and rachet. You will want a long extension also. First take the front two 14mm bolts out of the B pipe upfront. Let it kind hang there. Then take the 2 14mm bolts out of the rear of the B pipe. The hanger will still be holding the B pipe in there. Then pull the b pipe off the rubber hanger. You will need the rubber hanger peice for the strup B pipe as well. I took the old B pipe out and put the hanger off it and put it on the new Strup B pipe. Then put the new B pipe in there. Make sure you slide the back of the B pipe over the axle and then slide the hanger back on. I put the 2 14mm front bolts back in barely. Just mainly there to hold the pipe in its spot.
Then go back and slide the actual muffler section off the hanger as well. The exhaust should be out of there now. Take the rubber hanger off the stock muffler and put it on the Strup peice. Now take the Strup muffler section and hang it under the xB by the rubber hanger. Both peices should be in there now. They will be loose but that is ok.
Take the gasket that is supplied and one of the bolts and line it up and put one of the 3 bolts in the rear peice. Make sure that you are not smashing or bending the gasket in any way. Now take the remainder of the 2 bolts and get it all put together. Make sure that you tighten all 3 bolts in place. This is where the extension comes handy. Now go back up where you left the 2 bolts in the front of the B pipe loose and tighten them up. Make sure everything is tight and not hitting anywhere. I just grabbed the exhaust and shook it and it didnt hit anywhere. Now you should be able to start the xB and check for leaks.
This took me about a hour total and that was with getting everything jacked up and set to do the work. I hope this helps out.
You can buy the exhaust off my website. I do sell them as well.
http://www.nolimitzind.com/exhaustxb08.html
NoLimitzBuilt is offline
Old 02-14-2008, 03:13 AM
lvbitwiz's Avatar
And wear gloves! Damn heat shield is razor sharp!
Looks good dude
lvbitwiz is offline
Old 02-14-2008, 03:32 AM
1UP Crew
boooosty's Avatar
lol nvm great sound and diy
boooosty is offline
Old 02-14-2008, 04:03 AM
superboxcarxb's Avatar
give a sound clip!
superboxcarxb is offline
Old 02-14-2008, 04:14 AM
miketf1's Avatar
hey whats the diameter of the stock vs strup piping? metric please! i get confused with the SI system....
miketf1 is offline
Old 02-14-2008, 04:19 AM
why is the tc getting 4 years and the xa and xb only got 3 years?. My dealer told me about it.
Old 02-14-2008, 01:37 PM
Boxer_Rebellion's Avatar
Wow that's beautiful... nice walk-through too.
Boxer_Rebellion is offline
Old 02-16-2008, 06:24 AM
BFDBOX's Avatar
nice write up, looking good.
BFDBOX is offline
Old 02-16-2008, 04:53 PM
SoCalXB2's Avatar
is there anyvideo or anything of how this sounds?
SoCalXB2 is offline
Old 02-17-2008, 05:45 AM
lvbitwiz's Avatar
yes, I posted it in another strup thread
Damn I need a cookie....frickin low carb diet...
lvbitwiz is offline
Old 02-17-2008, 06:41 AM
CIONIDE's Avatar
PM me your address, I'll send a frickin cookie...
CIONIDE is offline
Old 02-17-2008, 02:29 PM
lvbitwiz's Avatar
WOOT!
lvbitwiz is offline
XB06
15
10-01-2022 10:24 PM
DJ_FroZone
25
05-30-2019 07:17 PM
dbg326
05-31-2015 05:29 PM
SpaceCaptain
05-11-2015 06:24 PM
DJ_FroZone
04-09-2015 03:42 PM
Quick Reply: DIY Strup Exhaust
