XB Failed Cosumption Test - Scionlife.com
Reply
Thread Tools Search this Thread
Old 02-17-2017, 12:51 PM   #1
Default XB Failed Cosumption Test
My 2010 XB just failed the oil consumption test. The dealer is ordering parts. They recommended that I do the following parts also at a lower hour labor rate since they will have the engine apart. I can do all or some of their recommended parts. Any thought on these?
Timing chain
timing chain tensioner
8 countershaft bearings
2 camshaft bearings
oil pump
tmuss is offline   Reply With Quote
Old 02-17-2017, 06:28 PM   #2
Greg S's Avatar
Absolutely non of those should need replacing on your engine unless you are well over 150,000 or they have wear on them due to oil starvation. Did they inspect them and show you the wear or are they just recommending it? BTW the timing chains have no scheduled replacement mileage and should be good for the life of the car. What mileage do you have on the car?
Greg S is offline   Reply With Quote
Old 02-17-2017, 06:32 PM   #3
Greg S
Thanks for the reply. They are recommending thee parts for replacement. The car has 142,000 miles on it.
Old 02-17-2017, 09:58 PM   #4
RichBinAZ's Avatar
Pretty sure the camshaft bearings are a matched set with the cylinder head - so they are not replaceable - without replacing the entire cylinder head.
My recommendation - PASS
RichBinAZ is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
