Fuel pump without return line
I mean.. are you boosted? If not, or even if you are, you probably don't need that beefy of a system. The full circular system is for some serious flow. I doubt you need all that. You're good to just plug and play whatever pump your using with your existing system.
YES!! Im boosted, my pump housing has like this small (i dont know) regulator or filter? It is like a small housing inside the big housing, lol, the small housing where the bomb is connected! I dont know if i can eliminate that small housing or not.
I'm installing rods and pistons so yes, i will need the fuel pump.
necesitas un retorno. si puedes instalarle una bomba con retorno a la guagua. el housing de plastico de abajo el flexible es para ayudar a q la gasolina se quede cerca de la bomba. puedes quitarle o dejarlo pero si se lo quitas en curvas la bomba se puede quedar sin gasolina. pero no vas a tener ningun problema en absoluto
No you don't delete threads because your question was answered. These threads stay alive so if anyone has this question, then they just just search and read it instead of posting a new one. We don't just delete threads.
Flyfishfreak
06-10-2016 02:55 AM
GetSlideways
Scion xD Drivetrain & Power
03-16-2015 11:30 PM
cid_mcdp
01-05-2015 02:45 PM
