Scion xB 2nd-Gen Forced Induction Turbo and supercharger applications...
Tire and Wheel drag strip set up?
Old 10-25-2014, 02:55 PM
scionxbpr's Avatar
Default Tire and Wheel drag strip set up?
What can happen if I have 18'' at the rear and I use 16 or 15 at the front with ET Street Radials?
scionxbpr is offline
Old 10-25-2014, 06:44 PM
Greg S's Avatar
If the are the same overall diameter it will be fine, if not then you can through the traction control off which will really suck if you're trying for track times. Also you're probably best going with a 16" because the vast majority of 15" wheels do not clear the brake assembly.
Greg S is offline
Old 01-20-2016, 01:25 AM
JDMSUV's Avatar
I would put on the stock wheels on the rear, if you still have them. More than likely they are lighter than the 18s. Also over-inflate the rears for less rolling resistance.
JDMSUV is offline
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
scionlife
371
06-02-2015 11:00 PM
toyotaisme
01-10-2015 10:24 PM
TheTripleC
01-04-2015 06:46 PM
scioninla
10-30-2003 08:01 PM
Quick Reply: Tire and Wheel drag strip set up?
