Alarm & remote start using OEM transmitters
Old 05-30-2007, 12:14 AM
Malibu_Rapper's Avatar
Default Alarm & remote start using OEM transmitters
I am about to pull the trigger on an OEM add on alarm. The Hornet 727T from Directed/Viper. It uses the door lock and unlock wires to allow you to use your OEM remotes. It adds starter kill, zones, siren, active arming, and a few other things to the existing OEM keyless entry system.
I have a feeling if I find the keyless entry box that I can figure out what wires do what and do most of my wiring there. Anyone have a chart or or wire colors they can share? Where is the box at?
The OEM remote start sequence leads me to believe that the keyless entry module also has an output that can be used for any other aftermarket remote start. I don't like the auxillary output trigger for the 727T because it is too easy to trigger by accident (just needs to lock pulses). So I want to find the aux output for the OEM remote start.
Anyone have the schematics for the OEM keyless yet?
Malibu_Rapper is offline
Old 05-30-2007, 03:43 AM
SmartAss's Avatar
The problem with the oem remote start is after its started you cant unlock the doors anymore.
Ill have the diagram up soon when I get around to it later this week. Should be the same as the TC.
SmartAss is offline
Old 05-30-2007, 04:06 AM
Hmm, that's interesting. I wonder what keeps the doors from unlocking? Is it the act of remote starting the car that triggers the output and disables the unlock feature? I just tried to remote start mine to see if it attempts to trigger a relay or does anything funny. But it doesn't do anything so it must know if a remote start module is installed somehow.
I'll do more research on the tC remote start module as well. Thanks!
Old 05-30-2007, 02:56 PM
SmartAss's Avatar
Yes you test for this by starting the car up then hitting the buttons on your key they dont work becuase they are disabled by the ignition trigger sent to the factory keyless entry system only way around it is to find the wiring diagram from toyota on the factory keyless entry and eliminate that wire.
SmartAss is offline
Old 06-01-2007, 01:36 AM
Guest
Guest
Posts: n/a
ok so i install the aftermarket alarms for my dealership and i do 10 brands of cars....the only cars dat u can use the oem keyless entry for the remote start is the chrysler jeep and dodge.....i do toyota,scion,subaru,kia,hyundai,mazda, mitsubishi also and always have to add new remotes....it is a hassle to some customers...but gotta live with it....but there are some modules out their that DEI makes where u can use the factory remotes on a toyota.......
Old 06-01-2007, 04:19 AM
SmartAss's Avatar
most american cars work and most foreign cars dont work there is a few exceptions
SmartAss is offline
toyotaisme
01-10-2015 10:24 PM
757_BRDFLY
01-09-2015 12:29 PM
BV19869
12-11-2014 06:05 PM
lexobx
Scion xD Drivetrain & Power
12-07-2014 05:52 PM
scionspecialistvegas
12-15-2003 11:21 AM
Quick Reply: Alarm & remote start using OEM transmitters
