amp for speakers
Old 12-01-2014, 07:36 PM
cwong1001's Avatar
Default amp for speakers
I been looking into a small amp that doesn't require much work to install. Hoping to install it behind the glove compartment so that I can just use the factory speaker wire from the radio. I have an aftermarket deck installed already. I was just looking for a little more power so that I can install component in the back door also. Most of these are around $100 on Amazon. Any suggestions?
The options are:
Pioneer GM-D1004
Pioneer GM-D1004 Compact 4-channel car amplifier ? 45 watts RMS x 4 at Crutchfield.com
Alpine KTP-445U Power Pack
Alpine KTP-445U Power Pack Upgrade any car radio to 45 watts RMS X 4 at Crutchfield.com
Kenwood KAC-M1804
Kenwood KAC-M1804 4-channel amplifier ? 45 watts RMS x 4 at Crutchfield.com
Clarion XC1410
Clarion XC1410 4-channel amplifier — 50 watts RMS x 4 at Crutchfield.com
cwong1001 is offline
Old 12-01-2014, 10:32 PM
Greg S's Avatar
Any one of those would do what you want. I like the Pioneer or Alpine ones the best. Whatever you do don't run the power from behind the radio though. The stock power line in the xB does not carry enough current to run any of those properly so you'll still need to run the power line out to the battery.
Greg S is offline
Old 12-01-2014, 11:57 PM
LostTiny's Avatar
Default alpine
The options are:
Pioneer GM-D1004
Kenwood KAC-M1804
Clarion XC1410
I have personal experience with the Alpine model. And it works just fine. I have to put in my XB, but with the factory radio it looks there's enough room behind the radio to mount it.
LostTiny is offline
Old 12-02-2014, 08:32 PM
cwong1001's Avatar
Thanks for the replies. Another question is what kind of fuse is needed or it does not need one?
Old 12-03-2014, 02:17 AM
Greg S's Avatar
Absolutely needs a fuse. Anything run directly to the battery needs to be fused within 15 inches of the battery, the closer the better. Just use the same size fuse as what is on the amp.
Also if you are looking for space there is a ton under the dash to the left of the instrument cluster. It's easiest to reach by removing the whole upper dash, also makes running any wiring very easy.
Link for dash removal - DIY - 2nd Gen Dash Removal - Scion xB Forum
Greg S is offline
Old 12-03-2014, 03:30 AM
cwong1001's Avatar
thanks again
prescottn
Scion tC 2G ICE & Interior
04-26-2016 01:14 AM
DannyBoy65
09-21-2015 06:23 PM
volume315
08-29-2015 01:31 PM
volume315
08-29-2015 10:28 AM
Quick Reply: amp for speakers
