AVIC D3 Install questions
Originally Posted by Bigfieroman
I have a D3 I am going to install this week, and I have the backup camera. Anyone know where is a good place to catch a backup light wire other than the rear bumper?
See pages 9 through 15
http://www.trdsparks.com/install/08545-00930inst.pdf
Originally Posted by BigBHaller
I see in the xB Nav installation guide that there is a SPD signal wire (Violet/White) on Page 12.
Would this wire work for the VSS signal (I'm assuming SPD means 'speed')?
Originally Posted by randode
for the speed sensor wire, try the purple wire behind the radio. this is the one I cut to make the stock navi play dvds while in motion.
Randode, based on what I said above, I would believe that the purple wire you cut is not the speed signal wire. The speed signal wire, if it was connected on yours, would be violet with a white stripe. If the wire was violet/white, and THAT was connected to something, I would be eternally grateful (and buy some stuff from you) if you could tell me where it went.
Wagonistas
Confirmed:
The speed signal wire from the VSS is the purple wire in the 20-pin rectangular connector behind the radio. This is the second from the right connector in the above photo. This was originally suggested by Randode and mostly confirmed by Smartass.
I just installed my D3, used this wire, and confirmed that the signal was being received by the unit.
Re: AVIC D3 Install questions
Originally Posted by jarero
Just bought my wife a new box on Sunday and have a huge list of parts on the way including a Pioneer AVIC D3. I have a few install questions that I haven't been able to find on the forums:
1) How do I find the VSS wire on the 08' (avic411.com doesn't have anything on it)?
2) Will the scosche install kit for the 06' work on my 08' (that's what the stereo shop is sending me)?
3) Can I use the 06' wiring harness?
4) Does anyone have any how to's on deck install, speakers, etc?
Thanks in advance for the help!
edit - must be a site sponsor in order to advertise on scionlife - cherryBox
I just picked up a D3 and plan to do the install myself. The VSS wire is the purple wire in the second harness from the right, correct? I heard purple/white and just wanted to clarify. Also did you hook up the reverse wire? If so where is that located?
Thanks!
Thanks!
I got my D3 installed and working great! Bypassed and rockin'
The installer knew i was going to bypass it and said he didn't hook up the speed wire because he had had problems with the bypass before when it was connected.
Has anyone else had problems? What exactly will the speed wire give me in terms of benefits over not connecting it?
http://www.compuplus.com/i-Pioneer-A...%20ELECTRONICS
I was a bit leary, but people here recomended it and on Avic411.com had many people buying from them without trouble. Delivered quickly and brand spanking new!
