View Poll Results: Thoughts?
Voters: 19. You may not vote on this poll
hot or not?
Before you sell it....
What model amp is it? Is it a mono amp, 2 channel, or...?
How do you have the subs wired to the amp?
If you can load the amp properly or is rated to take a 2 ohm or 1 ohm load you might be ok with what you have.
lol i know about the wiring and if i had the money id do a ill fiberglass set up but its a lanzar max power 282
when its bridged to 2 ohms it only delivers 450rms and i need at least 600 and yeah its a 2 channel
If those are 2 ohm speakers, and you are wiring them parrallel, you will have 1 ohm into each sub. Most likely you're going to have to upgrade your amp and spend a bit more. But oh God will it ever be worth it.
so i tried wiring it in series and it worked but their was a high pitch noies along with the bass and then when i took out the car again it stopped working and whenever i went to turn the input level up the subs whould just like randomly move up and down to full extension? wtf i tihink im just gonna ____ can this thing
its ok, looks like two boxes in one but over all not bad. BULKY for sure, you could go fiberglass and get more airspace and a harder hit with less mass. As for wires just remeber this if it were a show or something....wires are bad, never see wires unless you cant help it and if then make them look super smooth and organized tied down etc
wayneside
Regional - Pacific Northwest
09-23-2015 10:29 AM
