Cupholder leds problem and question
Old 07-23-2007, 07:51 PM
oni424's Avatar
Default Cupholder leds problem and question
I got 3 10mm leds pre-wired from radio shack. I hooked them up to my existing system of lights and the output is very dim. Any idea what went wrong? They are pre-wired and have resdistors built in....
oni424 is offline
Old 07-23-2007, 08:14 PM
MikeMayer's Avatar
too much resistance?
MikeMayer is offline
Old 07-24-2007, 02:39 AM
my08xb's Avatar
yeah that sounds like a resistance problem. do you know the voltage and the amperage of the 10mm?? id get a ohm meter and check the resistance of the lights.
If all of this is sounding like jibberish then go to google and look up led info and wiring techniques
my08xb is offline
Old 07-26-2007, 03:05 PM
frogbox's Avatar
does your existing system already have resistors built into it ?
if you tied in the new ones with resistors maybe, just maybe you got twice the resistance that they need.
check the resistance in your existing system to make sure, if it is already there, take out the newly added resistance and get your brightness you want.
frogbox is offline
Old 07-28-2007, 12:49 AM
timmer357's Avatar
Okay, I have done some searching on Google, dogpile, etc. I have got a basic idea of what to do, but it seems like the articles are either really basic or in depth. I was hoping to add an LED light (or two) to each cup holder. I was originally thinking I would simply wire them to the cigarette lighter. This was because it is very close, will only be on with the ignition, and would be adequate power. Now I am thinking it is too much power. Anyone have suggestions, knowledge, advice to offer?
timmer357 is offline
Old 07-28-2007, 01:53 AM
timmer357's Avatar
Is there such a thing as too much power if they have resistors?
Old 07-28-2007, 04:16 AM
marcemarcxB08's Avatar
make sure the leds you are installing are wired correctly together... because if the leds are wired in series the light will be dimmer as opposed to having them wired in parallel which should make it brighter
marcemarcxB08 is offline
Old 07-28-2007, 05:10 AM
timmer357's Avatar
So can I wire them (parralel) from the factory cigarette lighter? I was thinking of buying the pre-wired orange ones from Oznium.
Old 07-28-2007, 05:41 AM
as long as it is wired in parallel it should give you the brightness you desire
Old 08-01-2007, 07:58 PM
oni424's Avatar
Mine are wired in line... hmm have to get under the dash this weekend and do some work.
oni424 is offline
randomsuper
20
06-13-2015 10:56 AM
XB06
05-30-2015 02:42 AM
CPL_Radar
03-05-2015 05:42 AM
TotalChaos
13
02-04-2015 10:24 PM
toyotaisme
01-10-2015 10:24 PM
Quick Reply: Cupholder leds problem and question
