Dome light/ map light mod - Scionlife.com
Reply
Thread Tools Search this Thread
Old 06-15-2007, 02:22 AM   #1
StyleWagons
Scott17's Avatar
Default Dome light/ map light mod
If you want your map light to mirror your dome light for more brightness while still working independantly with the switches, all it takes is a transistor and resistor. Toyota has used this same basic setup for a while now on a few different cars and instead of posting a super how-to write-up I'll just give a link to an old write-up for a Tacoma that works the same way. If you understand electronics and are the slightest bit handy, you will have no problem with this one. If you DON'T COMPLETELY UNDERSTAND THIS MOD, please don't PM me 4 years from now asking for a wiring diagram or something. Find someone locally with a basic electronics background and ask them. PLEASE! Believe it or not this link will contain ALL the information you will need to complete this mod if you study it carefully and use your noggin. OK, with that out of the way here's the link: http://www.toyotanation.com/forum/t91499.html
Scott17 is offline   Reply With Quote
Old 06-15-2007, 02:39 AM   #2
XBFred's Avatar
YGPM
just kidding
XBFred is offline   Reply With Quote
Old 06-23-2007, 08:05 AM   #3
jackjon's Avatar
i am in process of completing this mod, i can't wait! i only wish that we could somehow tie the dimmer switch on the dash into this system so we could actually turn on the lights without having to reach upward... now that would be a great mod ;)
jackjon is offline   Reply With Quote
Old 06-23-2007, 05:48 PM   #4
jackjon's Avatar
some quick notes... the maplight on the xb only has a two prong terminal, there is no third bent out, however there is a third wire which is bent back that does not connect to the terminal...
also, having trouble finding the wire heading to the dome light... i will have to get in there with a flashlight and see if i can find it.
Old 06-25-2007, 01:51 AM   #5
No need to do that kind of mod for xB...
I've used 36 LED module on each of the light...
They are crazy bright..
Two 36 white LED module on the map light..
And one 25 low profile blue LED module for middle dome light...
LEDmod is offline   Reply With Quote
Old 06-25-2007, 02:26 AM   #6
jackjon's Avatar
yes, but i got a panoramic sunroof... my dome light is behind the back seat now! so there is literally no light in the front... and when will your LED's be available? you know i want to order everything from you ASAP... just waitin for it!
Old 06-25-2007, 03:01 AM   #7
You can use the white low profile 25 LED module
They are 1/4" thick, so it will fit in the rear dome light housing..
E-mail me and I can get you one.... Sean@LEDmod.com
Old 10-16-2010, 09:58 PM   #8
xtylerx's Avatar
I know its like 10 years later, but has anyone actually done this?
xtylerx is offline   Reply With Quote
Old 10-17-2010, 06:51 AM   #9
TrevorS's Avatar
Perhaps I'm out in left field, but I have plenty of light in my xB2 when I enter in the dark. I've changed all my interior lights to LED and the dome illumination works just fine (12 power SM LEDs). I'm not suggesting this map light mod is bogus, just that it may not be all that meaningful in practice.
TrevorS is offline   Reply With Quote
Old 10-17-2010, 07:58 PM   #10
xtylerx's Avatar
It's not really a brightness issue, I have the mega LED dome light from Oznium. I just think it would be a cool feature, the more light the better.
Old 10-17-2010, 09:33 PM   #11
Quote:
My LED is same as the oznium....
When I get a chance I'll try it on my box....
Old 10-23-2010, 02:05 PM   #12
xtylerx's Avatar
Nailed It!
(video)
Old 10-23-2010, 06:27 PM   #13
Nailed It!
Also map light work right??
Old 10-23-2010, 07:00 PM   #14
xtylerx's Avatar
Yeah, put diodes on the map lights so you can use them without triggering the dome light.
Reply
Thread Thread Starter Forum Replies Last Post
DIY - tC2 Independent Fog Light Mod Thread 2.0 SkillFreeJake Scion tC 2G Aero & Exterior 17 07-27-2015 12:34 AM
LED station lights horsefeathers Scion xB 2nd-Gen ICE & Interior 7 01-19-2015 12:52 PM
I'm back! cavalierkid888 Introduction Forum 1 01-08-2015 04:42 AM
ScionJohn's bB Light Mod Opr8r Scion xA/xB 1st-Gen ICE & Interior 24 11-30-2003 11:38 PM
Besk one's Blue Cold Cathode Engine Compartment Mod Besk_one Scion xA/xB 1st-Gen ICE & Interior 6 11-17-2003 09:28 PM
Tags
avalon, ca, diagram, dome, interior, led, light, lights, map, mod, orange, scion, sequoia, store, wiring, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
