how to remove A-Pillar cover - Scionlife.com
Reply
LinkBack Thread Tools Search this Thread
Old 08-15-2007, 08:42 AM   #1
Default how to remove A-Pillar cover
Hi there!
Just working on deadening some creaks around the car and would like to remove the cover on the A-Pillar. I was able to pull it away from the top, but then a "latch" which is attached to a grommet keeps the cover from being removed all the way, I can reach the base of the grommet, but am not sure if a flathead is sufficient to remove it.
And nope, this is not the dreaded welding issue, just some plastic on plastic.
Thanks!
smxb is offline   Reply With Quote
Old 08-15-2007, 03:18 PM   #2
I just yanked as hard as I could til it came off. Of course I broke the black latch but it was not needed as I still had the other plastic plug to keep it in
Noodles5666 is offline   Reply With Quote
Old 08-15-2007, 03:26 PM   #3
ah, thanks for the info, my only concern is that the latch acts as a "hook" in the event the side curtain airbags deploy, so that the a-pillar trim doesn't fly off the pillar and hit something/someone... so I'm trying to find a less "destructive" method.
Old 08-16-2007, 02:09 AM   #4
chadfo's Avatar
I haven't tried removing mine yet but did you try pulling straight up? Sometimes they really do make things simple. Other times not.
chadfo is offline   Reply With Quote
Old 08-16-2007, 02:17 AM   #5
yep, no go. But I do believe that you can insert a screwdriver behind the grommet and pull it towards the center of the car, it will pop off, but only after a lot of force, then you'll probably have to pull out the tabs again that's on the grommet so that there's still some tension.
I couldn't work around it, I did have to cut the latch from the grommet, but then re-engineered it with some other tools/parts so that it still serves its purpose.
Oh, and the pillar is dead quiet now
I may actually eventually order the grommet, but truth be told, it'll work just fine with how I redid it (read: zip ties!)
Old 08-21-2007, 08:45 PM   #6
my08xb's Avatar
i didnt know you could remove the a-pillars, because of the airbags.
So is this dangerous to do??
my08xb is offline   Reply With Quote
Old 08-21-2007, 11:11 PM   #7
nope, not at all... just as long as you don't puncture the airbag AND place the cover back properly.
Old 08-30-2007, 06:03 PM   #8
Sponsor
Team No Limitz
You can get the black peice off the A pillar. I took mine out last night to pull the headliner down. You can pry the black peices right out of the metal on the a pillar, then when you go to put the peice back on. You just alighn the black peice with the hole again and it will snap right back in there.
NoLimitzBuilt is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
DIY: xB2 (2008-current) 2" class III hitch mod SpaceCaptain Scion xB 2nd-Gen Suspension & Handling 0 05-11-2015 07:24 PM
Cover for back seat removal? Prolific998 Scion tC 1G Owners Lounge 0 05-08-2015 06:56 AM
tC: Tc1 California Car Cover Superweave - Still In Box *lowered price* Erager09 PPC: Exterior / Styling 0 04-23-2015 02:50 PM
Forum special 10% coupon code for CalTrend seat covers | CARiD carid Exclusive Sponsored Sales 0 01-22-2015 01:49 PM
What the???? [Windshield Water Leak] HELP DibujoB Maintenance & Car Care 14 11-21-2003 01:26 PM
Tags
08, 2005, 2006, a, cover, pillar, pillars, pull, removal, remove, removing, scion, tc, trim, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
