iPhone not recognized by factory radio
Old 07-23-2008, 12:45 PM
mark's Avatar
Default iPhone not recognized by factory radio
I recently updated my orginal iPhone with the 2.0 update, and now when I plug in the phone to the iPod cable, it no longer prompts me to go to airport mode, and when I click the iPod/Aux button nothing happens.
Does anyone have an idea baout how to fix this?
Thanks in advance!
mark is offline
Old 07-24-2008, 12:01 AM
ssfblue's Avatar
There should be a fix, whether it's through software/firmware updates or a physical adapter. Hopefully soon!
It's weird though that you are getting that problem with your iPhone 2G... it should be working so it looks like it might just be a problem with the 2.0 ware.
ssfblue is offline
Old 07-26-2008, 03:31 PM
willow's Avatar
i have the same problem....
willow is offline
Old 08-01-2008, 10:48 PM
Setiri's Avatar
Not sure what's up with your iPhone, but just to chime in, my iPhone 3G works just fine. Plugs right up, gives a notification about "this device isn't actually made to be used here" then asks if I want to go into airport mode. Answer no and it goes into regular operation via my head unit controls. Admittedly it does keep the error screen on, wish they'd fix that.
Setiri is offline
Old 08-02-2008, 06:26 AM
Tortfeasor's Avatar
Default Re: iPhone not recognized by factory radio
Thanks in advance!
I just got my 09 xB and after reading your post, I was nervious. I tried it out with my 2g iphone upgraded with the 2.0 firmware, and it worked perfectly.
Maybe you need to do a factory restore under itunes?
Tortfeasor is offline
Old 08-16-2008, 12:25 AM
AndreyCo's Avatar
I've got 2.0.1 on my original iPhone. Works fine in the t1808 (2008 xB). Once in a while it will say "COMM ERROR" or "NO SONGS" but a quick unplug/replug usually fixes it.
btw, it also worked fine with 2.0 software.
AndreyCo is offline
Old 02-03-2009, 06:12 PM
Djbombsquad's Avatar
Does not charge though like the dealer rep said it would. I am uspet. I went on a huge trip and sucked up all my power from videos and music.
Djbombsquad is offline
Old 02-03-2009, 06:23 PM
rockthebeef's Avatar
The latest iPhones/iPods have different pins for charging than all the older iPods. There is an adapter to fix this issue:
https://www.scionlife.com/forums/vie...iphone+adapter
BTW, iPhone 3G=2G (2nd generation). The original iPhone would be "1G". 3G refers to the data network, not the hardware version. It's all semantics. Even some salespeople call the original iPhone the 2G.
rockthebeef is offline
herwig
Scion tC 1G ICE & Interior
03-23-2015 04:19 AM
NewBox06
02-03-2015 12:36 PM
minter66
12-15-2014 01:45 PM
Granth77
11-25-2003 12:11 AM
MaxPower
10-22-2003 09:22 PM
Quick Reply: iPhone not recognized by factory radio
