Removing headliner and rear seat
how do you remove the headliner and bottom part of the rear seat.
Headliner:
should I disconnect the negative ? I'm just afraid of setting off the air bags.
Seat:
I know there is a clip but i dont know how to pull it off
Thanks
Headliner:
Seat:
Thanks
Team No Limitz
the headliner is not fun. You have to pull all the pillar peices A, B and C pillars. Then you have to pull all the handles and visors. Then there is cables that run down the headliner and you have to pull the center dome light out through the top of the headliner. It is not the funnest thing to do. I just did mine.
A short quick but strong pull should help you with that and most likely the worst thing that could happen just to break some clips which you would always have enough to put em back.. To avoid pulling out wires is a short quick pull, and theyre not usually mounted to the headliners, make sure the engine is off or you f wanna really make sure disconnect the bat for the airbags..
HotLavaDestiny
02-08-2015 05:25 AM
carid
01-22-2015 12:49 PM
