Grinding noise at the rear end
Old 08-03-2011, 01:55 AM
THSBXRX's Avatar
Default Grinding noise at the rear end
I have a 08 Xb stick I noticed today at low speed 5-15 mph I get a intermittent grinding noise. The Xb is lowered , dual exhaust etc, etc, I took my mechanic for a drive got all about 5' and he heard it. We put it on the lift spun the front and rear wheels no noise. Checked the rear breaks all is good. My thoughts are wheel bearings but I don't want to spend $$$$ chasing a problem. The Xb has 154,456 miles on it. Any ideas?
THSBXRX is offline
Old 08-03-2011, 02:05 AM
Blackedout011TC's Avatar
Brake caliper sticking, worn brake pads. or wheel bearing. The wheel bearing may only grind with weight on it. My first guess would be the brakes.
Blackedout011TC is offline
Old 08-03-2011, 02:28 AM
TrevorS's Avatar
How much is it lowered? As the rear camber increases, the pressure on the bearings becomes more uneven -- could be a bearing issue. Unloaded, nothing would probably be evident !
TrevorS is offline
Old 08-03-2011, 05:01 AM
THSBXRX's Avatar
2" drop in the rear 1" in the front , im leaning towards the wheel bearings seems like the logical reason and i thought about a sticking caliper but the pads are worn the same on both sides.
THSBXRX is offline
Old 08-03-2011, 05:45 AM
Utah Scions
xseveredveganx's Avatar
Bearing isn't all that bad. About $240 from RockAuto. OEM ones are $286.
xseveredveganx is offline
Old 08-03-2011, 05:48 AM
jnaval's Avatar
What are you lowered on? Another way to test the wheel bearings is grabbing it to see if it has any play.
jnaval is offline
Old 08-03-2011, 07:27 AM
CIONIDE's Avatar
My rear wheel bearings were both completely toasted at 76,5xx miles. I had been hearing noise for a little while, but waited until I needed to take the xB in for another warranty issue as well. Thank goodness for the Toyota ExtraCare extended service agreement!
CIONIDE is offline
Old 08-04-2011, 05:29 AM
Zsanz's Avatar
extended care picked up the bill? i think mine are on the way out but im on trds you think theyll have a fit ?
Zsanz is offline
Old 08-04-2011, 07:24 AM
CIONIDE's Avatar
ExtendedCare picked up the total bill. If you're on TRD I would think you'd be covered since it's all Toyota, unless they can prove another fault.
CIONIDE is offline
Old 08-04-2011, 01:56 PM
AAG
DeepSouth Scions
AAG's Avatar
Do bad wheel bearings "howl" at highway speeds?
AAG is offline
Old 08-04-2011, 03:45 PM
CIONIDE's Avatar
^^ Yes, they can.
CIONIDE is offline
Ferretgrrl
10-15-2018 02:50 AM
NewBox06
02-03-2015 04:02 AM
ScionVan
11
12-02-2003 09:37 PM
smilygo
11-01-2003 11:26 PM
Kodokan_4
10-29-2003 05:49 AM
Quick Reply: Grinding noise at the rear end
